Current recipe is 9 lbs flaked corn to about 1.5 lbs crushed malt barley 2 row in 8 gallons of bottled spring water.
I'm using a home built stainless milk can still with a copper 1.5" collection column and 3/8 OD copper tubing to a coil condenser. Propane heat source.
Have been getting very consistent and excellent product so far! I'm averaging about 2 and a quarter quarts of drinkable, very smooth very flavored whisky. Even the wife likes it and she is beyond not normally a fan of sipping whisky of any kind! lol Likes that canned garbage mojito mixer toilet water stuff normally
The 2 and a 1/4 quarts I'm bottling at the end are around 50% alcohol after I make my cuts. I started tossing the heads and only putting the tails into the next runs now. I noticed I was just wasting propane and time out in the wood shed at -25 celsius doing runs and collecting more and more paint stripper jars of heads before cutting into my mid run anyway so I just chuck them now except for the last cup or so before it breaks clean into my mids. I mix that in with the tails and into the next run.
My question is this now, I used to dilute my final product with spring water down to 40% by volume down from 50%. I am finding that I actually quite like the taste of tails!
Including the deep tails that end up around the 25% -20% mark about where I shut off the still.
I always was told and from doing research before I started this hobby that the tails is supposed to be an overpowering flavour but I don't find it even remotely so. Not sure if it's just my rig and mash/setup that's producing the very pleasant tails though. Or is this normal?
What I started doing was actually using my tails cuts at 30%-25% to dilute my mid cuts from 50% down to 40%. I end up with more product and the flavour is very very nice.
I'm getting a very sweet corn whisky that's smooth as water with no burn/bite at all and just enough of the warmth at 40% now.
Am I the only guy that actually enjoys the taste of deep tails and is cutting my mids with it to drop ABV? Am I messing something up by doing this?
