Scrubbies turning Black
What is the black stuff that is on my copper scrubbies after a run? It appears to comes right off in the hot backset or soaked in vinegar.
You WILL get addicted to this forum.
The Parent site is REQUIRED READING!!!
I think that it's the residue caused by the copper reacting to the sulfur in the wash. I get it on the inside of my copper lyne arm and it can be wiped off with a finger. I wouldn't worry about it. It's just a sign that the copper is doing its job.
"If you can't dazzle them with brilliance... baffle them with bullshit."
"Don't steal. The government hates competition."
"Believe none of what you hear, and only half of what you see"
20lt small pot still, working on keg
Even if your scrubbers are 100% copper,there going to blacken some.If you use too much,or not enough acid in your wash or mash,it will make them,and the copper in your still do it alot,and even discolor the spirit.I had that problem before,and it was caused by too much acid,and too much leftover neutrents.I backed off on both,and havent had it happen since.
