thermometers
Posted: Sat Dec 31, 2016 11:11 am
by bigbuck
looking for a reputable place to buy an accurate thermometer, any suggestions
Re: thermometers
Posted: Sat Dec 31, 2016 11:21 am
by FreeMountainHermit
Placement of the therm as well as the intended use is needed to give you a recommendation. All therms are not created equal. Hope this helps, Sir.
Re: thermometers
Posted: Sat Dec 31, 2016 11:58 am
by bigbuck
I need one to put in mash to watch temp remotely, I recently tried nchooches bourbon and my brand new piece of s**t thermometer was about 45 degrees off and pretty sure was the cause of mash nor working off correctly
Re: thermometers
Posted: Sat Dec 31, 2016 12:20 pm
Trying to get a feel here. How big of a mash and what are you mashing in ?
Re: thermometers
Posted: Sat Dec 31, 2016 12:23 pm
by bigbuck
15 t0 30 gallon want to do it remotely though
Re: thermometers
Posted: Sat Dec 31, 2016 12:26 pm
by bigbuck
and btw that holler you live in really does sound like a magical place!!!!!!
Re: thermometers
Posted: Sat Dec 31, 2016 1:03 pm
Thanks. It definitely is.
Kinda stumped here as you require remote reading. I'd use a good quality cooking BBQ therm such as a Maverick or others
https://www.google.com/search?q=remote+bbq+therm+images" onclick="window.open(this.href);return false;" rel="nofollow
The downside to this or at least the one I use is that the probes are not submersible .
Use the long meat probe instead of the grate probe and only insert it into the mash an nch or so.
Best I can do,...
Re: thermometers
Posted: Sat Dec 31, 2016 1:57 pm
by cob
those BBQ thermo's have limited range.
I have a long probe (2') compost thermo I use for compost.
think about any thermo in your fermenter with a wifi camera to monitor it'
monitor with your smart phone from any where in the world.
I'd be worried about security though.
Re: thermometers
Posted: Sun Jan 01, 2017 7:41 am
by rad14701
How would one stir their mash and insure that there is no scorching remotely...??? Just as with running a still, mashing requires constant attention while heat is being applied... Once the heat has been turned off, not so much...
Re: thermometers
Posted: Sun Jan 01, 2017 8:22 am
by bigbuck
it is specifically for nchooches bourbon mash while corn is cooling to 150 degrees
Re: thermometers
Posted: Sun Jan 01, 2017 8:38 am
by Pesty
My local ace hardware has about 20ish different kitchen thermos on the wall that would all work in some way.
just about all the thermos including the cheap ones are adjustable to set the correct temp, check google for how.
Re: thermometers
Posted: Sun Jan 01, 2017 10:57 am
by bigbuck
the one I recently used was a piece of crap and was off by a mile and it was not a cheap one either
Re: thermometers
Posted: Sun Jan 01, 2017 10:58 am
Pesty wrote:My local ace hardware has about 20ish different kitchen thermos on the wall that would all work in some way.
OP desires remote monitoring.
Re: thermometers
Posted: Sun Jan 01, 2017 11:00 am
bigbuck wrote:the one I recently used was a piece of crap and was off by a mile and it was not a cheap one either
Wondering if it has a calibration feature.Might want to check if it does.
Good luck.
Re: thermometers
Posted: Sun Jan 01, 2017 1:42 pm
by rgreen2002
I have this little fella right here:
- ThermoPro TP07
I think it has gone up a little in price since I got her. She has the fancy pre-programmed meat settings but I can easily dial in any temp (as an alarm to tell me when I reach temps) I want for mashing (like 200F). I mostly use it during the cool downs when I am waiting for temp drops to add other grains or pitch yeast. FMH is correct though.... DO NOT SUBMERGE THE PROBE.... unless you like either WAY off temps or buying new probes.
Here is the amazon link:
https://www.amazon.com/ThermoPro-Wirele ... hermometer" onclick="window.open(this.href);return false;" rel="nofollow
