Ok,
This may have already been answered someplace,
I am up to page 15 of Jimbo's electric conversion. I was wanting to do this for a while now,
However, I have a Simple Pot still, old style, All copper. I figure I already know the answer but figure its good to check with the pro's.
Is there ANY reason why I should not set up my copper boiler with an internal element and the SCR controller ?
I can handle the wiring just wondering if for some reason copper would act different than a SS keg.
I'm already in the process of selecting the parts needed to convert the top cap from a flour paste seal to a 4" tri clamp. Seems copper stuff for this is not real easy to find.
just to add, The only reason for adding the internal element is for faster heat up times. I like the way my rum finishes on the slow stove top element.
Heating Element in a Copper Pot ?
Re: Heating Element in a Copper Pot ?
Try this
http://stilldragon.com/index.php/compon ... brass.html" onclick="window.open(this.href);return false;" rel="nofollow
- Swedish Pride
only reason not to do it is that it would not look "old school"
so no good reasons, go for it
Don't be a dick
Thanks Dfitz,
I had found those on their site. Think thats where I'm gonna order the SCR Kit from also. Aint much more $$ than ordering parts and assembling myself.
Yes Swedish pride I agree. My plan would be to install the Element from the back side so the front would still have that natural look. Only the Temp ( Yes I know,I only use it to gage when to cut back the heat.) and the Drain I already installed. would be visible .
Thanks for the replys
My heat up time now, on a 1600 watt element stove is about 1.5 hours on a 5 gallon wash.
Just do it Mr Bee - You'll be amazed how you got on before, once you have the internal element with a decent power controller. Over here we have copper water tanks with immersion heaters in virtually every house.
I was looking at those but they charge 14 bucks for shipping, so it's $32 dollar copper ferrule,.. so got another from ebay for 22 shipped. Only difference was mine was set for the pipe ID of M pipe while i have L pipe.. took some sanding to make it fit but glad I did as my ferrule fits ID while the still dragon is OD, leaving the ferrule on the outside of the pipe vs the inside of mine.DFitz wrote:Try this
it's just an image thing as the end of my pipe just has the tri-clamp ring and clean copper as I soldered from the inside of the pipe.
http://www.ebay.com/itm/182283158024" onclick="window.open(this.href);return false;" rel="nofollow
- Soft batch
I have no regrets with my electric copper pot. I can run inside with no flame/ventilation issues. I just have a plastic box attached to the side to cover the connections - who is going to see? I build things for functionality, not for public appearance - which we shouldn't be doing anyways!
