TPSR Controller
TPSR Controller
I had an RCD and an MCB already and had just received a D52 2048, this is a device that fits the same rail as the aforementioned devices ad displays Volts ,Amps, Watts.
The assembly is trial only and I will find a box to build it in asap but I tested it for earth continuity and it was safe. I may need a larger heat sink or a fan but at 1KW it is barely warm and the max I'll run it at is 3KW. A Zs test did not work presumably due to the TPSR but the RCD operated as it should.
This is a first try at posting pics so I hope it's OK
Re: TPSR Controller
cool design
keep an eye on it over extended periods though, I have to blow on my Controller every hour or so
eventually I will get around to putting a fdan on it
keep up the good work
- skow69
Re: TPSR Controller
You might get more replies if you define some of those acronyms.
Re: TPSR Controller
FYI- this is the D52-2048: https://www.amazon.com/D52-2048-AC80-30 ... B01J5JQ7TO" onclick="window.open(this.href);return false;" rel="nofollow
And this is the data sheet for the TPSR-25:
