Adding 240 while contractor is there
If it plugs in, post it here.
bhh
Post by bhh »
I know I need to do my own research but I'm in a bit of a unique situation as I have a contractor at my house now finishing up a basement bathroom. I ask him about adding a 240v outlet in my brew area and he said no problem but now is the time to do it before he closes up the wall (finished basement). There are a few extra slots in the panel and we have the drywall around the panel opened up since we needed an extra circuit in the bathroom.
Anyway, I'm currently running my father's 30L copper alembic on a 1500w hotplate but plan to upgrade to a larger boiler at some point in the future. I like electric for indoor wintertime distilling but it just dawned on me if I ever want 240 in my brew area, now is the time to do it and I will probably go ahead and add another 120 on a separate circuit as well. Anything in particular I should ask for, plug type, etc.?
Thanks and I promise to do my homework but won't be able to fully wrap my head around all the particulars of 240v heating options before the contractor gets this wall and panel area closed up.
Re: Adding 240 while contractor is there
30 amp twist lock. Set a 30 amp breaker. 10/4 minimum wire.
crazy
Post by crazy »
Just my opinion but I would make sure he runs 4 conductor for your 240v wire , it will make wire ring up fans in your controller simpler . It is code in my state to run it that way but your state may vary . Good luck on the upgrade !
bhh
Post by bhh »
Thanks guys! That's perfect. I'll tell him to run 10/4 on a 30A breaker with a twist-lock receptacle.
bhh wrote:Thanks guys! That's perfect. I'll tell him to run 10/4 on a 30A breaker with a twist-lock receptacle.
:thumbup:
Cha....ching! But now is the best time...best price.
bhh
Post by bhh »
For sure. This guy has done a lot of work with me and is time+materials on a day-rate anyway so it isn't going to cost me anything really other than material costs. Super excited about being able to bring >5 gallons up to temp in under 2 hours :crazy: Thanks again. :thumbup:
Snackson
Post by Snackson »
If you can swing the change, have him put in a GFCI breaker. I have 50a in my garage and plug a 50a spa panel into that with a built in GFCI breaker as it was cheaper and is only used for brewing/stilling.
bhh
Post by bhh »
It's not too late, that's a good idea also. I already switched the 120s in that area out to GFCI but we can just use a GFCI breaker for the 240. Will cost a little more but probably worth it.
StillerBoy
Post by StillerBoy »
bhh wrote:Super excited about being able to bring >5 gallons up to temp in under 2 hours
How's 20 minutes or less with 5500 watt on 240 volt with a 6 gallon load.. I'm up to speed in 18 minutes for stripping, and about 14 minutes with spirit run of 6 gallon at 35% using a 7 gal keg..
Mars
– Albert Einstein
bhh
Post by bhh »
StillerBoy wrote:How's 20 minutes or less with 5500 watt on 240 volt with a 6 gallon load.. I'm up to speed in 18 minutes for stripping, and about 14 minutes with spirit run of 6 gallon at 35% using a 7 gal keg..
Mars
That's sounds absolutely amazing but I'll have to change up my routine, which is now...
Wake up at the crack of dawn on Saturday morning.
Charge the boiler and turn on the hot plate
Make a cup of coffee (on a separate circuit of course :roll: )
Drink coffee, read HD.org, make another cup of coffee, read more HD.org
Mix up some rye flour paste
Make a mess with rye flour paste
Fill up the flake with cold water
Fill up a 20 gallon tote with cold water
Drop a submersible pump into tote and hook up lines to flake
Make another cup up coffee
Read more HD.org
piss
oh oh!, nope. Get my balls (jars) out of the closet.
piss again
eat breakfast
drip...drip...drip...
:yawn:
