Hey folks looking for some info on building condensers.
I have two designs picked out and material for both.
Bear with me as I'm not 100% on terminology.
Ill start with I am aiming to produce both distilled water
and corn whiskey possible venturing into flavoured spirits later.
First design I believe is considered a shotgun condenser.
On a 5 gallon still is half inch copper inside three quarter copper
with garden hose attached sufficient?
Second will be a worm. Is half inch flexible copper ( actually three eights)
big enough for same 5 gallon still?
Building condensers
Re: Building condensers
You may want to read this thread first and it should provide you with most of the answers.. the condenser your are referring to is a liebig.. shotgun has multiple tubes..JJbrad29 wrote:First design I believe is considered a shotgun condenser.
http://homedistiller.org/forum/viewtopi ... =1&t=34062
Mars
– Albert Einstein
– Albert Einstein
- cranky
This is probably everything you need to know about condensers, http://homedistiller.org/forum/viewtopi ... 65&t=20655
I don't like flake stands (Worm type) because they tend to have issues. In my opinion a liebig is the way to go. This is a really good thread on that
http://homedistiller.org/forum/viewtopi ... =87&t=9247
One thing that is concerning me right now is that you may still have a lot of reading to do. If you haven't read then already read and follow the first 2 links in my signature.
Thank you sir. Answered most my questions there. Basically if I'm nervous about the cooling, I'll make it longer and or pack it.StillerBoy wrote:You may want to read this thread first and it should provide you with most of the answers.. the condenser your are referring to is a liebig.. shotgun has multiple tubes..JJbrad29 wrote:First design I believe is considered a shotgun condenser.
Mars
I'm still nervous about the worm I think it'll work though.
Any info on the point where the cap transitions to the condenser. Can I run half inch directly of the cap or does it need to be a bigger outlet and taper down?
+1 to what Cranky said. Read, read and read some more, starting with the two links in Cranky's signature.
I love my liebig, so glad that I went with that.
Be safe, learn and enjoy the ride cause it sure is a fun one!
Edited: I see your responded to Cranky's post while I was writing mine. Check out this thread http://homedistiller.org/forum/viewtopi ... 60&t=26460
it is the Diagrams and Plans thread and has great info that you will find useful.
All new distillers please read Crankys Spoon Feeding
