What packing material do you prefer?
Copper Mesh/Scrubbies
14
27%
Stainless Mesh/Scrubbies
4
8%
Ceramic
2
4%
Glass
9
18%
Lava Rock
10
20%
Cut Up Copper Pipe
0
No votes
Prismatic Spirial
9
18%
Springs
0
No votes
Other
3
6%
Total votes: 51
Rain Distillate
Post by Rain Distillate »
What packing material do you prefer and why?
If other, please specify what material and why you like to run with it.
Hunter7922
Re: What packing material do you prefer?
Post by Hunter7922 »
Wondering if you could use 3M Scotch-Brite Copper Scrubbing Pad
Rain Distillate
Hunter7922 wrote:Wondering if you could use 3M Scotch-Brite Copper Scrubbing Pad
As long as it's a copper Scrubbie and not a copper coated Scrubbie. Make sure to source them, to verify.
Lyonsie
Post by Lyonsie »
Marlbes all the way.
I thought i was wrong once,
But then i found out i was mistaken.
Kill the women, and rape the men.
BlackStrap
Post by BlackStrap »
I use copper mesh, easy to pack and unpack in my column... can be cleaned and reused, and copper removes sulfites, when distilling wines.
Most questions can be answered here http://homedistiller.org/ and here http://homedistiller.org/forum/viewforum.php?f=46
The one who cuts the firewood gets twice the warmth
Hunter7922
I've seen post about marbles, but how would you install them in a reflux column
thepatchworkdoll
Post by thepatchworkdoll »
Hi there
SPP for me hands up. The best Ive tried so far in my opinion.
Regards
Patch
Rain Distillate
Hunter7922 wrote:I've seen post about marbles, but how would you install them in a reflux column
make a retaining screen (drill holes in bottom of column and slide a few pieces of solid copper wire (12ga) then solder in place. now add a copper scrubbie and load your marbles. if you added more wire you could probably do w/o the scrubbie.
You could also make one out of some copper sheet. Drill a bunch of holes and slide down inside the column so it sits on top of a ferrule.
or buy a screened ptfe gasket. kinda expensive. don't use anything measured in microns....toooooo small.
Desvio
Post by Desvio »
If "glass" equals marbles, then yes marbles it is.
I like messing around with the amount of packing in the column and marbles are easy to scale by weight.
People say that I'm a bad influence. I say the world's already f#cked -- I'm just adding to it.
Hunter7922
OK, perfect!
Sorry for this and I'm sure its posted some where, but SPP?
As for the marbles. Question i would have is once you're finish with the run. How would you clean the column and the marbles? just water, no scrubbing.
To new and learning
thanks
Hunter7922
Looked it up on google, SPP (Spiral Prismatic Springs)
Sounds good, but a little more than i want to go with as a newbie.
Thanks though
nuntius01
Post by nuntius01 »
never thought of using cut up pipe. i use mesh. might look into that.
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
Cu29er
Post by Cu29er »
Of those who have used different packing schemes ...
-how does the back pressure compare with each type?
-what is the % alc or proof output of each type given same stack diameter and height?
I've seen the SPP is favored in many reviews/tests, but really expensive and hard to find.
Rig I've seen: straight empty pipe = 40-60pr, 7 plates with holes = 80pr, SS scrubbies = 120pr; limited number of runs to be valid though.
masonsjax
Post by masonsjax »
Ive been very happy with glass marbles.
Klein
Post by Klein »
Glass marbles [THUMBS UP SIGN]
DAD300
Post by DAD300 »
SS Scrubbies are the most cost efficient, but SPP is King for HETP and neutral!
The pressure in a column can be anything you want with Scrubbies.
Cleaning? How much do you clean a column or packing you just ran steaming alcohol through? Copper, take out and soak in lemon juice, rinse. SS, pour some hot water down the top of the column.
DSP-AR-20005
Evil Wizard
Post by Evil Wizard »
There have been a lot of positive posts on scoria - I can't seemed to find it but I am having great success with lava rock balls. I soaked some in vodka for a couple months and found no degradation.
geolite/hydroton
geolite/hydroton
Sometimes called Hydroton or geolite, I bought 50L for about $40 CAD. The balls were smaller than some I've seen in the past, and the red melted coating was inconsistent, showing 20% of the porous dark grey interior. This is ideal because it allows more porosity. Even the fully red coated balls have a nice rough texture allowing a lot of surface area. When you pour the water on it you can hear the holes fill like Rice Krispies.
They pack in my 6" column beautifully like marbles but at a fraction of the weight. This is vital considering I'm lifting 4' of type K copper pipe (much heavier than dwv/m/k) up onto the 30 gallon boiler. If it were marbles I would need handles on the column and they would interfere with my pipe insulation.
distiller
distiller
I rinsed 20L of geolite in water several times before loading them into my 4 foot column (plus 1 foot Cooling Management section of 3/8" tube wrapped 4 or 5 times). I have a perforated copper disc floating in the bottom of the column with scrubbies on top of it to keep the lava balls from falling or blocking the holes.
I get full reflux with the condensor, and after 40min, I tweaked the 3way water valve to drop the reflux condensor to a trickle and open up the product condensor. I hit azeo right off the bat, pulled off meths and heads from the sugar and wheat wash.
For hearts I cranked the speed up to the limits of the product condensor (1/4" copper inside 3" pipe) which was 5900watts and got 17.6 Litres/hour at 88%-90%. At 4450watts I got 12L/hr.
In regards to the goofy looking lyne arm - I'm just using pieces from my 3" continuous distiller (clocked at 22.6 L/hr of wash input and 5.4 L/hr of 60%-67%abv ethanol output)
I'm pretty happy with geolite. Way less work than building plates and easier than breaking up scoria.
Work is the curse of the drinking class. "Would you like some water?" "No thanks, I'm Irish."
Louchebag Absintheur, Apostolic Alcoholic, Whisky Icarus, Bathtub Alchemist.
Started 2005, went Pro 2017. Federal Excise 51-SL-262.
Stillernz
Post by Stillernz »
Evil Wizard wrote:There have been a lot of positive posts on scoria - I can't seemed to find it but I am having great success with lava rock balls. I soaked some in vodka for a couple months and found no degradation.
+1 for Scoria. I cleaned mind through water and then boiled it twice and then do a vinegar run too and that's stuff is superb. I got 2 massive bags for 10nzd score!
I'm a "glass marble guy". Easy to load and unload. Easy to clean. Comparable to SPP for effectiveness. And when it comes time to replace....very economical.
I have to wonder why marbles and glass didn't get separate categories.
Back in the mists of time some folk used broken wind shield / screen glass as packing in reflux stills.
I suspect a few still do use that and other forms of glass besides marbles.
The results of the survey might tell a different story if marbles and glass had their own categories.
This is an interesting thread as all I have used is homemade copper packing. If something works great, why change? I do have some experience with plates and rocks hanging around Mash Rookie and all his experiments with packing. He built a glass column so he could not only test its efficiency but also visually inspect the process. He documented it on a thread here about 3-4 years ago.
OtisT
Post by OtisT »
I prefer copper mesh in my 2" column.
Lots of surface area.
Light, light, light weight compared with other packing.
Rinses and dries quickly when you take it out.
I don't need to Solder wire or add a screen to the bottom of my column to hold the packing in.
I can easily change the density of the mesh roles.
I can add just a few inches of packing at any location of the column. Sometimes I only use a half role at the top for light reflux.
If I roll the mesh just so, with a cone/point at the bottom, I can redirect reflux off the walls and back into the center of the column.
Storing mesh when not in use is compact.
A 1 pound role for about $14 can last dozens of uses.
StillerBoy
Post by StillerBoy »
I'm a lava rock user.. there are light in weight, and easy to clean, and their efficiency is a good if not better than 1/2" size marbles.. the size of the pieces makes all the different in their efficiency, to big and they are useless, dime size are the best for 2" and 3" columns, and 3/8" size for 1.5" columns..
Mars
– Albert Einstein
