I want to use part of this design as a preheater.
Now I have a bit of a problem; My pot takes around an hour to get up to temp, then about 2 hours to do the run proper. This means that there is around twice the power going into evaporating the product as in heating the wash. So if the vapour is condensed in a worm in the next wash tank, that should mean that the next wash gets up to "producing temperature" some time before the first run is exhausted.
Dorn's still has a vent pipe allowing any vapour produced to be incorporated into the first coil of the worm and thus in the production run. In some ways this would be great, because when the first run is exhausted and the next wash is discharged into the still proper, it would already be partially distilled. HOWEVER I am not happy with that, as I do single or 1,5 runs and need to get rid of the fores on each run.
As far as I can see I have two choices; a) incorporate a bypass valve so when the wash gets to temp, the valves close / open and the remaining bypasses that part of the worm or b) reduce the coils in the worm so not all of the heat is extracted.
Opinions please ?
