Gday all,
I want to get into AG distilling but I'm caught up on what the best type of mash tun is going forward.
Do people care to share there mash tuns and sparging techniques for their mash tuns.
Thanks,
Mash tun ideas?
Mash tun ideas?
Re: Mash tun ideas?
The simplest and cheapest would probably be a $30 Walmart cooler. Great insulation, and very easy/cheaply add a flex tubing "false bottom".Sparrow wrote:Gday all,
Do people care to share there mash tuns and sparing techniques for their mash tuns.
Thanks,
Swedish Pride wrote:
Re: Mash tun ideas?
What's the efficiency of something like that going to be?Antler24 wrote:The simplest and cheapest would probably be a $30 Walmart cooler. Great insulation, and very easy/cheaply add a flex tubing "false bottom".Sparrow wrote:Gday all,
Thanks,
Re: Mash tun ideas?
I mash with a 10 gallon Coleman drinking cooler. I put a gridwork of copper pipes in the bottom for the liquor to collect and drain out when lautering. With my processes, it works quite well at extracting the sweet liquor. And the insulation helps hold the mash temperatures (somewhat).Sparrow wrote:What's the efficiency of something like that going to be?Antler24 wrote:...probably be a $30 Walmart cooler...Sparrow wrote:...the best type of mash tun...???
If you have a stainless keg, you could "severe the head" and use that to mash in. The stainless is easily cleaneable using brewery cleaners and it will hold the hot mash without degradation, although insulation would help maintain mash temperatures better.
An old potato boiler would be a fantastic mash tun...stainless steel, approximately 40 gallon capacity and complete with a steam jacket...ideal for mating with a steam generator for heating and boiling. But this solution is more commercial. Potato boilers can be sourced used at resturant supply salvage contractors.
But as suggested, the insulated plastic ice chests/drink coolers are easily and successfully adapted for this function.
