is my wiring correct?
- Guilty
Hi,
If people are worried about helping each other with the wiring of their equipment how are we to get things built?If you are worried about telling me how to wire my controller don't. Just please tell me if it is right or wrong. Then I can do more searching to see if anyone has the same thing working correctly. So far I have not seen or understood any controllers built the same,Here is my controller diagram . Thanx
Re: is my wiring correct?
Look if you designed that circuit, you probably know more than most on here ! - If you didn't you have to tell us where it came from. Mine came hassle free & cheap from china and I just connected the 220 volt wires to the input and the output
- HDNB
i'm not sure what's messier, the wiring or the diagram...so i can't tell.
but...if it works, then it's good. if it don't then it's not. That's the great thing about electricity. Unfortunately there is a cost to test it out if it's wrong.
now i drink for evil.
Your schematic looks right to me, albeit messy and hard to follow.
You parallel the voltmeter to the input voltage and use the toroid transformer to measure the conducting current through the SSR by measuring the +V leg (voltage input of SSR). The SSR output runs out to your element and back to the terminal block.
All in all, if that's the way you actually wired the circuit, you should be OK, ie - no blue smoke.
edited for correction: (I had a followup look at your schematic)
Your toroid transformer is on the input voltage leg (+V) going to the terminal block and it actually should be on the SSR output terminal (+V to the element, or even the -V return from the element). With the toroid where it is now, you'll also measure not only the current going to the element, but also the current going to the voltmeter, even though the latter current is very small.
Of note, with those digital volt/amp meters, you want to measure the input voltage as you have. But you should measure the current flowing out to the element alone.
Guilty it will work . It's the same old same old curcuit that nearly everyones been using .
My only pedantic comment would be to have the Current transformer on the element black wire not the supply black wire . It is pnly pedantic but you want to be measuring the element current not the element + the ammeter power curcuit current .... yeah yeah I know its probably immeasurable but I did say I was pedantic once or twice :DEdit : posted same time as SS
I agree that the current xfmr should be on the load side for more accuracy. I wouldn't be worried about the current consumed by the meter, but by measuring before the SSVR, you will also be measuring the power that is dissipated by the SSVR. That can be significant, otherwise it wouldn't need a heat sink. If you want to measure how much power you are using then it is fine the way it is. If you want to measure power delivered to the heating element, then move it.Yummyrum wrote:Guilty it will work . It's the same old same old curcuit that nearly everyones been using .![]()
Good point about dissipation in the SSR redwood but unfortunately it is in series with the element so placement of the current transformer isn't going to help this issueRedwoodHillBilly wrote: I agree that the current xfmr should be on the load side for more accuracy. I wouldn't be worried about the current consumed by the meter, but by measuring before the SSVR, you will also be measuring the power that is dissipated by the SSVR. That can be significant, otherwise it wouldn't need a heat sink. If you want to measure how much power you are using then it is fine the way it is. If you want to measure power delivered to the heating element, then move it.
Question for you RWH,
Does the SSR work by "duty cycle" of the voltage wave? Or does it work like a tube (current valve)? If it is duty cycle management, then the power dissipated in the SSR occuring during the "off state" would be minimal, right?
My control circuit uses a Triac to control the output voltage by triggering "off" until the voltage recrosses the "zero point". Energy dissipated internal to the Triac is due to the internal resistance of the silicon junction.
If Rad were here (if only) I know he would chime in on this discussion.
The dissipation in these VR type SSRs occurs when it is switching state . It is this period of only a few microseconds each half cycle that the internal triac is noether fully on or fully off . It dissapates a huge amount of power for a very short amount of time .
Think of maximum cpu clocking speeds . Again it is the swithching transitipn which generates the heat
Ooops... Brain fart. Of course current will be the same, there will just be a voltage drop across the triac depending on junction resistance kinda like Rds in FET. Ignore my earlier post.Yummyrum wrote:Good point about dissipation in the SSR redwood but unfortunately it is in series with the element so placement of the current transformer isn't going to help this issueRedwoodHillBilly wrote: I agree that the current xfmr should be on the load side for more accuracy. I wouldn't be worried about the current consumed by the meter, but by measuring before the SSVR, you will also be measuring the power that is dissipated by the SSVR. That can be significant, otherwise it wouldn't need a heat sink. If you want to measure how much power you are using then it is fine the way it is. If you want to measure power delivered to the heating element, then move it.
- HDNB
i recall Rad learning the hard way to do the current xformer on the supply side of the ssr, i think it was because the square wave output from the ssr lets the smoke out the ammeter if you place it on the output side. but maybe that was just a specific cheap ammeter. or maybe my memory sux.still_stirrin wrote:Question for you RWH,
It's not the current sensing transformer but the voltage measuring connection ( which is also the power supply to the meter) that was the issue . The voltage measuring curcuit seems happy when connected before the SSR but all it can show is the supply voltage .. not really all that helpful ... but it keeps the smoke in .
The OP has this correct
The current sense transformer can be connected anywhere in the element curcuit to measure the current .
- Guilty
Thank you all for replies .
I moved the Current transformer to the output side on the black wire.Going out to garage to plug it in and hope it does what I want it to.
Thanx
It worked! No sparks no smoke no problems. Thanx again
Thanx
