Sulfuric acid for battery use
papapro
Post by papapro »
Recently I was looking for regulating pH in mashes etc and the advise was to use sulfuric acid as lowering pH.
I could not find the acid around here easily so advise was to use sulfuric acid for batter use.
I looked for MSDS data sheet and found the ingredience content.
Herev is MSDS:
Please do not use this product.
1370534206926_6402_MSDS_SkyHook_Batteries.pdf
(93.19 KiB) Downloaded 123 times
Yes I am a Novice with 40+ years of doing this hobby
distilling is like sex the slower the better and everyone is happy
fermenting is opposit to sex the faster the better
der wo
Re: Sulfuric acid for battery use
Post by der wo »
Noone recommended to toss a battery in a mash. This is a pdf about a battery, not about battery acid.
papapro
Post by papapro »
Der Wo: I said "Sulfuric acid for battery use"
Not FROM battery, I would never recommend to use acid FROM the lead battery.
PapaPro
Pikey
Post by Pikey »
Whatever you said papapro, der wo s right. The document you published refers to th ewhole battery - lead, antimony, arsenic and all ! :lol:
papapro
Post by papapro »
I am sorry I just rushed with posting at that time I did a lot of reading of MSDS's about sulfuric acid must have slipped.
Yes you and Der Wo are right in the future I will be more careful.
Regards PapaPro
Pikey
Post by Pikey »
No problem papa - so long as we get the right result at the end :thumbup:
RedwoodHillBilly
Post by RedwoodHillBilly »
I posted that in the other thread where he said the same thing, guess that he doesn't read all the threads that he cross posts in.
der wo
Post by der wo »
Whatever. I think the case is closed. Papapro did a mistake and he knows that now. No problem.
RedwoodHillBilly
True. (not so) Gentle reminder not to cross post and to read responses. [/end soapbox]
