Hi!
I've been distilling for a while, but this is the first time I've had this problem.
Simple sugar wash. Wash tasted fine, but end product has what I can only describe as a slight "vomit" flavour/taste.
Was it my cuts, or something else?
Slight vomit smell/taste
Re: Slight vomit smell/taste
I've heard tell of that "vomit smell" in infected washes - but not the way round you describe - I can only think left overs from last stilling - ie mucky kit - is that a possibility ?
- NZChris
It will be butyric acid from an infection in the ferment. Use the HD Google Search for vomit and you should get a quite a few hits.
But the butyric acid I had in my dunder smelled of pineapple (slightly) Once distilled and never any vomit smell in the final distillate, only in the dunder itself.
This a first I've heard in a sugar wash, it's possible that the fermenter had some contamination from a previous ferment?
- NZChris
That is because it has been converted to the ester, Ethyl butanoate.Shine0n wrote:But the butyric acid I had in my dunder smelled of pineapple (slightly) Once distilled and never any vomit smell in the final distillate, only in the dunder itself.
Now that would stand for the op as well wouldn't it?
If it were an infection in the ferment and was distilled it would then create the ester as well, no?
I'm looking up the term for distilling on Google about Ethyl Butanoate.
- NZChris
It needs acid for the reaction, so it is best to allow time for that to happen in the wash, rather than distil it and be stuck with it.
- HDNB
it does modify after distillation, but 3 years later...it's still modifying (it's still pukey, but interesting) but the distillate was vomitorium bad when it went on the wood in march 2014NZChris wrote:It needs acid for the reaction, so it is best to allow time for that to happen in the wash, rather than distil it and be stuck with it.
now i drink for evil.
- NZChris
There are components in the wood that help, but the OP has a sugar wash and is probably wanting some quick drinking likker.
