Beer keg safety issue
yakattack
Post by yakattack »
Alright. This is a safety question. One of my original boilers is a true 15 gallon beer keg. It was never molested as it was run on a propane burner. The question is. Can I still use this as a beer keg under normal operating pressure or will having used it for a boiler make it unsafe to pressurize?
kiwi Bruce
Re: Beer keg safety issue
Post by kiwi Bruce »
The carbonating pressure is only 15 to 20 PSI... that's if you are force carbonating. Serving pressure is 5 PSI or less...I don't think there is a issue at 20 PSI that a Stainless Keg would fail. But you could test it... I was given a soda keg that had a pin hole leak. I repaired it with a stainless button head screw and Harris #9...I ran the thing half filled with water to 100 PSI and left it over night, just to test if it had any other flaws or weak stops...it didn't, and I'm still using it.
(It breaks my heart, but) I've finally decided my future lies
Beyond the yellow brick road...from Elton John
cede
Post by cede »
Should not be a big deal.
If you did not molested the sanke part and the gaskets are in good condition, you should be good.
Just put back the head in place with a bit of water inside the keg, pressurise at 30 psi and wait a few hours and check if you still are pressurized.
Kegs are made to resist rough handling and as far as it has not been heated dry to cherry red it should be ok.
