barrel slow leak problem
- HDNB
8 months after fill a small barrel started a small leak, right on the bottom.
it's right under the band.
i tried a heat gun and parrafin wax.
any other suggestions?
now i drink for evil.
- HDNB
Re: barrel slow leak problem
yeah i guess...just drive the bung home with a 2 lb hammer.The Baker wrote:Turn it over....
- Fiddleford
It may be because the barrel has pressure from the alcohol evaporating inside causing the leak, I know you want this when ageing a spirit but if its leaking it will be a problem. Maybe try cooling off the barrel and see if it leaks then if it does might need to empty it and repair it. I'm not a cooper but I work alongside one and absorbed a whole lot of knowledge.
- Twisted Brick
Didn't BadMotivator report that he seals his oak heads with melted beeswax?
You could try tapping that band toward the middle of the barrel a tiny bit ...its easy to over do it ...just a little at a time is enough. Ive fixed a few that way, but nothing is guaranteed.HDNB wrote:it's right under the band.
Or...put a shotglass under the drip and periodically “empty it”. No waste...no worry.
I like that SSstill_stirrin wrote:Or...put a shotglass under the drip and periodically “empty it”. No waste...no worry.
- fizzix
Get your leak fixed, HDNB?
I had one giving me trouble so I cleaned the affected area, put some (natural, edible) soy wax on it and coerced it with a hair dryer.
No more leak.
No more leak.
Now that hair dryer was a touch of brilliance!fizzix wrote:Get your leak fixed, HDNB?
No more leak.
- HDNB
still no joy. i did hit it with parrafin and a heat heat gun. i may have to empty and take a couple rings off, the leak is right under the end band.
maybe i should try some rad stop leak...
- bitter
sometimes a leak I have drilled a hole and put a piece of wood to drive in the hole... depending on the leak etc.. will not work in all case..
Driving the bands down can help depending on the barrel also.
B
B
- jonnys_spirit
I seal leaks with bees wax like soldering. Expose and prep the leak area. Sand and clean. Heat with heat gun then rub the bees wax into the heated and sanded area so the heated wood draws the wax deep into the spot where the leak comes from.
Repeat till tired or happy and drink some whiskey.
Has worked every time so far.
Cheers and good luck!
-jonny
-jonny
If leaking under one end there's nothing necessarily wrong with standing the barrel on end leak up.
I tried to fix two old, small barrels that leaked.
god knows how much time I spent.
So far as I know they still leak.
A baker I am, a cooper I am not.
Well, that explains the username.The Baker wrote:I tried to fix two old, small barrels that leaked.
I had been curious
