Found this on LinkedIn.
Startup Info
- MoonBreath
Startup Info
- HDNB
Re: Startup Info
forget something?MoonBreath wrote:Found this on LinkedIn.
now i drink for evil.
- MoonBreath
Re: Startup Info
https://www.forbes.com/sites/fredminnic ... -this/amp/" onclick="window.open(this.href);return false;" rel="nofollow
There tis.
There tis.
Re: Startup Info
I saw that yesterday as well. Lot of truth with a bit of hyperbole but a pretty solid piece. I think his minimum 5-7 years until profitability are a little extreme but other than that, he does a good job of pointing out pitfalls and roadblocks that folks can expect to encounter in opening a distillery.
Liberty Pole Spirits
68 West Maiden Street
Washington, PA 15301
libertypolespirits.com
DSP-PA-20045
DSP-PA-20045
Re: Startup Info
Depends on how big you try to go at the beginning and how much out-lay.Huffy2k wrote:I saw that yesterday as well. Lot of truth with a bit of hyperbole but a pretty solid piece. I think his minimum 5-7 years until profitability are a little extreme but other than that, he does a good job of pointing out pitfalls and roadblocks that folks can expect to encounter in opening a distillery.
- MoonBreath
Re: Startup Info
Another nugget..
https://www.distillerytrail.com/blog/cr ... A.linkedin" onclick="window.open(this.href);return false;" rel="nofollow
Re: Startup Info
I got this far and stopped reading ..."A single batch goes in, is heated carefully to a specific temperature and maintained"
We all know that you can not do that ..or we should by now if we don't.
- MoonBreath
Re: Startup Info
Rick Stillwagon is pretty prolific in the craft scene, so maybe it was just a explanatory mistake.
But hes talkn about maintaining a certain head temp, which we all know Can be done with proper rc adjustment.
I do it every run, run a single batch up to 180°, and hold it there..How many likkers are deciferred, temp cuts.
But folks that don't use or believe in thermometers will never understand, or admit it works because they're limited to running only likker without therms.
But we're talkn craft techniques here, and ALL distilleries, craft or full blown, use thermometers (on columns esp).
A flute without a thermometer is like a guitar missing a string, it'll never get used to its full potential..
And you'll never know what different music or likker you coulda made..Sure theres folks say they don't use the speedometer in their car too, but....
Ifn you can't run likker every whicha way, therm or no therm, then you're way behind, not even knowing the specifics of your own product.
