New Controller
- Oldvine Zin
New Controller
]So after a couple years of using an embarrassing (hey I'm a journeyman electrician) just enough to get by controller built with parts laying around it's time to build a correct one.
More pics later
One of the short cuts I took, think that I mentioned it in another post being a know it all you can get 110 vac from 1 hot and ground in a 220 vac system - all good until your 110 volt device shorts to ground, = 110 volts to anything grounded to your system, quite the surprise when you touch the boiler. Please don't do that.More pics later
- NZChris
Re: New Controller
I have always had a large earth strap clamped to my boiler so that I don't get any surprises.
- Oldvine Zin
Re: New Controller
Isolated from your controller should be good. Through a missed wired controller not so much
OVZ
OVZ
- Oldvine Zin
Re: New Controller
Almost got all the parts for my new controller, just waiting for the ground fault circuit breakers to arrive.
One heater control with amp and voltage readout, one 220vac on/off for my cooling pump, and one 110vac on/off for either my cooling fan or mash pump. All three circuits GFIC protected.
OVZ
Just a simple but safer controller, no fancy "zero's and ones" - straight analog. One heater control with amp and voltage readout, one 220vac on/off for my cooling pump, and one 110vac on/off for either my cooling fan or mash pump. All three circuits GFIC protected.
OVZ
Re: New Controller
Oldvine.. are you going to use two potentiometer with your ssr, while you are at it..
Two potentiometer give you better control, one 47K and another 470K, so that you are about to fine tune the heat input..
Mars
Mars
– Albert Einstein
– Albert Einstein
- Oldvine Zin
Re: New Controller
Wasn't going to but since you mentioned it it sounds like a good ideaStillerBoy wrote:Oldvine.. are you going to use two potentiometer with your ssr, while you are at it..
Mars
One more part to order
OVZ
Re: New Controller
I'm sure you will not regret having install two pots.. it is so nice to have the ability to fine tune the power..Oldvine Zin wrote:Wasn't going to but since you mentioned it it sounds like a good idea
Mars
Here's mine..
– Albert Einstein
– Albert Einstein
Re: New Controller
Looks good Mars! I like the extra adjustment for heat. Old one looking forward to seeing he finished product
Re: New Controller
@ stillerboy , your V meter reads 240 v and your A meter is 13amps that calculates to about 3120watts but your power says 2073 watts . Wondering which one you trust ?
Re: New Controller
Sharp eyes Yummyrum..
Yah those meters have a discrepancy issue between the amp and kilowatt reading.. I've tested three of these meters, all have the same issue, but all read the same, so I use the amp reading mainly for my settings.. and have done a test using an amp meter to compare the different, when I first started using these meters, and came to the realization that to calculate the difference was really not an issue, as long as I used the amps and tune my operation based on the amps..
Thanks BS for the compliment.. dual pots does make it easier to fine tune.. the second pot full range is only 3 amps, so it is easy to play with quarter / half amp settings..
Mars
Mars
– Albert Einstein
– Albert Einstein
- sambedded
Re: New Controller
I've tested this and couple similar meters. ll off them definitely not a high precision devises however they are accurate enough.StillerBoy wrote:Sharp eyes Yummyrum..
The discrepancy you observing is due to meter connection. You connected voltage sensing wires "before" SSR . So it always shows 240B or near it. While voltage on heating element is actually decreasing when you set dial below 100%. However wattage value displayed by that meter is acculturate enough, So if you take TrueRMS voltmeter and measure voltage directly on heating element and multiply by your amp reading you should get value pretty close to wattage you see on display.
- Expat
Re: New Controller
Looking great, very clean and well built!
Are you running k-type thermal probes for the temps?
I really like the total energy summary on your one panel. Definitely a nice to have item if you like data
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Re: New Controller
The meter is connected to the flow through wire, that is the transformer.. should it be connected at a different location or wire..sambedded wrote:The discrepancy you observing is due to meter connection. You connected voltage sensing wires "before" SSR .
I don't know what a k-type thermal probes means, but what I have are meters that use DS18B20 probes, which I shorten to the length I want, cut them and attached them with 3 wires mic plugs..Expat wrote:Are you running k-type thermal probes for the temps?
These meters work quite well for what I do.. one at the bottom of column value, one at the top of column value (reflux setup), and one for the water temp (bottom one).. at a glace, I can see what is happening, or where I'm at in the run, etc..
Mars
Probe setup..
– Albert Einstein
– Albert Einstein
Re: New Controller
Sorry Oldvine.. we are somewhat hijacking your thread.. but on the other, providing you with some addition input on your new controller built..
Mars
Mars
– Albert Einstein
– Albert Einstein
- Oldvine Zin
Re: New Controller
Its all good we can never have too many inputs and suggestions, it's all about learning. I try to learn something new here every day.StillerBoy wrote:Sorry Oldvine.. we are somewhat hijacking your thread.. but on the other, providing you with some addition input on your new controller built..
Mars
So getting back to the two control pots I assume that you wired them up in series to give the fine tuning?
And oh I just received the Din mount GFI'S today OVZ
Re: New Controller
OVZ , Was wondering why you chose not to use an a analog meter . Suspect there are a few ones and zeros in that digital one you got thereOldvine Zin wrote: Just a simple but safer controller, no fancy "zero's and ones" - straight analog.
OVZ
Analog meters are good at averaging the chopped up waveform from a phase controller and they don’t blow up if you connect the voltmeter section to the element like some digital ones do . I don’t see the point in getting a digital meter that has to have the voltage section measuring the input voltage just so it won’t blow up . Might as well just have an ammeter I guess . But maybe the one you got will survive just fine with the voltage meter connected across the element .
( Incidentally ... if you are not aware , there a quite a few posts on this subject . Digital meters get their power to operate from the voltage measurement section . When connected to a chopped up waveform from a phase controller and in particular when its turned down low , Digital meters smoke up . This is why common advise is to connect the voltage measurement section before thr controller .... rendering its use questionable )
Regarding the two pots , yes connect in series as a course and fine adjustment . ... either way round . It doesn’t matter which one goes where in the series curcuit .
Re: New Controller
While it’s certainly not as sexy or high tech as digital stuff a simple analog volt meter is easy to hook up and dead reliable. In the end it’s just a number to give you a reference to run from. I can easily calculate watts or whatever from that. My rig likes to run beteeen 95 and 105 volts most of the time once it stabilizes. 220 volt, 5500 watt element. It’s also really east to see the needle swing when I adjust it. I’m a gadget guy but this works for me
Re: New Controller
I gotta’ agree with Yummyrum and Big Stogie here (FWIW).
My controler has both, an analog volt meter and an analog ammeter but the ammeter is what I use to adjust the power. The current swings proportionally to the power and the ammeter can easily display the changes. It is easy to see the needle swing between 5 amps and 15 amps, which is where my 4.5kW/220VAC element runs on 110VAC circuits. The 20 amp gage does not use an external toroidal transformer, it is wired “inline” with the output circuit. So it reacts very quickly to power adjustments.
The volt meter isn’t much benefit really because it swings between 110VAC and 95VAC with the same power adjustment. Because of the way a zero crossing triac switches on and off, the voltage doesn’t drop much before the current flow is closed. Also, analog meters do display a RMS voltage, not peak instantaneous voltage.
Bottomline, once you’ve learned the performance of your boiler, the power (wattage) consumed is not really a necessary number to adjust the boil rate. You can easily get your measurement que from the current alone. And it will be a more “dynamic” display for your feedback. Instead of watts....just note the amps. Quickly you’ll know when and where to adjust the current to your heat element throughout the run to get the production rate desired at the spout.
Re: New Controller
I'm in agreement there..Big Stogie wrote:In the end it’s just a number to give you a reference to run from.
I like the set up I have, for many reasons, but the main one is that at a glance, I can determine what is happening in the boiler, and what the output is, without having to stand over the still and do all kinds of measuring..
When refluxing, the temp at the bottom of the column, the temp at the top, and the water temp allows me to dial it in the same every time a run is done..
But that's just me, I like to see what the action is doing..
Mars
– Albert Einstein
– Albert Einstein
- Oldvine Zin
Re: New Controller
OK you and everyone else has shamed me into going all analogYummyrum wrote:
OVZ , Was wondering why you chose not to use an a analog meter . Suspect there are a few ones and zeros in that digital one you got there![]()
OVZ
- Oldvine Zin
Re: New Controller
First meter showed up today, didn't catch it when I placed the order but it's rated for 50 Hz - should be accurate enough on 60 Hz
OVZ
OVZ
- NZChris
Re: New Controller
My Chinese analogue Ammeter is not trustworthy when used with an SCR controller. When testing it without the interference of the SCR, it appears to be accurate.
- Oldvine Zin
Re: New Controller
Still waiting on parts - a few set backs on some of the parts I ordered not being correct
OVZ
OVZ
- bolek
Re: New Controller
About digital meter... Cheap Chinese power meter can work only with clear sinus. They show nonsens when you connect device with phase regulation, in simple ittoo less points at sinus but calculate it as sinus.
Really good meter will be expensive. I think that the best option i to get power meter who is use by by power plants(?). This device must be accurate from it's nature, also have good connector so is safly. Meter withdrawn from use is very cheap, but you must looks for model who show also actual data (power, current). Some device show it but in hidden options.
Re: New Controller
What are your plugins called? under what name to look for them on AliExpress?Oldvine Zin wrote:Almost got all the parts for my new controller, just waiting for the ground fault circuit breakers to arrive.Just a simple but safer controller, no fancy "zero's and ones" - straight analog.
OVZ
- sambedded
Re: New Controller
Regular analog amp and volt meters show incorrect value on non-sinus waveforms as well. Actually many of "cheap chinese power meter" surprisingly accurat even on chopped sinus after phase angle controller. For example this one - https://www.ebay.com/itm/NEW-PZEM-004-A ... 3229990150" onclick="window.open(this.href);return false;" rel="nofollowbolek wrote:About digital meter... Cheap Chinese power meter can work only with clear sinus. They show nonsens when you connect device with phase regulation, in simple ittoo less points at sinus but calculate it as sinus.
- Oldvine Zin
Re: New Controller
Not sure to what you are calling plugins?pretender wrote: What are your plugins called? under what name to look for them on AliExpress?
Did a little bit of work on the controller today: Drilled some holes - and
started filling them
OVZ
Re: New Controller
Oldvine Zin
Power plug and socket.
- Oldvine Zin
Re: New Controller
The power in is a nema 14 50pretender wrote:Oldvine Zin
Element power is a nema L 6 30
220 volt pump is a nema L 6 20
Aux pump is a nema L 5 20
OVZ
- Oldvine Zin
Re: New Controller
So one of my setbacks was that the cool din mount gfic circuit breakers I bought were listed as two pole 240 vac but in reality are one pole and a hot = 1 hot and 1 neutral
and the only other breakers that I could find were marine grade and lots of bucks.Scrapped the idea of having separate gfic breakers in the panel went with just a 50 amp on the main
OVZ
