Sources of Molasses
Anything to do with rum
Budapest8485
Sources of Molasses
Post by Budapest8485 »
I am struggling to find molasses by the gallon or 5 gallon amount in the USA. I can mail order it, but would prefer to buy something local. Any suggestions?
3 x 60 inch Bokabob, 8 gallon boiler, 4500w
3 inch pot still head, reduced to 2 inches, then to 48 inch 1/2 condenser. 8 gallon boiler, 4500w
Irishgnome
Re: Sources of Molasses
Post by Irishgnome »
Do you have a TSC nearby? Take a look: http://www.tractorsupply.com" onclick="window.open(this.href);return false;" rel="nofollow
If not, check a local feed store. I live in a fairly urban area and we have a good local feed store in town.
Good Luck!
Cheers.
Irish
"There is something about yourself that you don't know. Something that you will deny even exists until it's too late to do anything about it."
Budapest8485
Irishgnome wrote:Do you have a TSC nearby? Take a look: http://www.tractorsupply.com" onclick="window.open(this.href);return false;" rel="nofollow
Good Luck!
Cheers.
Irish
Yes, there's one not too far away. I wonder if this has preservatives in it: https://www.tractorsupply.com/tsc/produ ... _vc=-10005
Irishgnome
Tater should be able to help you out with the feed grade molasses, maybe PM him.
I used a feed grade molasses that I picked up from the local feed store. According to the owner it had natural sulfur in it, but no preservatives.
You can always contact the manufacturer.
I remember someone on here posting an image of the same brand molasses not to long ago.
Has anyone else used this?
TSC, at least my local one, is good about ordering items in for me that they normally don’t carry.
Local bakers are also a good source for larger (5 gallon) quantities.
Cheers
Irish
Irishgnome
Here you go: viewtopic.php?f=3&t=58570
Cheers
frunobulax
Post by frunobulax »
GOLDEN BARREL Is the cheapest I've found, even with delivery. If your local,(Pennsylvania) you can pick it up.
Also consider their SUPREME baking molasses. It's more money, but the additional sugar content more than makes up for it.
bluefish_dist
Post by bluefish_dist »
Golden barrel from web restaurant supply is the best deal I found. You can buy in gallons or 5 gallon pails.
Formerly
Dsp-CO-20051
Haven’t bought in a while but I am thinking I pay less than what has been listed below for 3 gallons of blackstrap molasses in my local feed store.
hellbilly007
Post by hellbilly007 »
Good Luck!
Cheers.
Irish
I've used the Evolved Habitats molasses per the suggestion of ShineOn. It took about 10 days to finish at ~80°F.
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
frunobulax wrote:GOLDEN BARREL Is the cheapest I've found, even with delivery. If your local,(Pennsylvania) you can pick it up.
Good post!
I happen to be driving down there today to grab 30 gallons :lol: . They are the best, and I always get the supreme. I have a 5 gallon barrel to start filling.
I love my rum season :clap:
Shine on you crazy diamond."
thecroweater
Post by thecroweater »
Lots of guys have used Evolved Habits with no issues. This can be bought from any tractor supply, Cabelas or Southern States Co Op for around $9 a pale from memory. It's 2 years since I've been to the states and so that long since I've seen it but I'd imagine it would not have gone up much if at all since then.
What sort of recipe are you thinking of following with it?
WillieP
Post by WillieP »
I have not done this yet, but when the time comes I'm going to try taking this route.
https://www.walmart.com/ip/Herd-Life-Li ... l/24817058
Looks to me to be 5 gallons with free shipping to the store for $38.24 US
Just my thoughts,
WillieP.
Expat
Post by Expat »
WillieP wrote:I have not done this yet, but when the time comes I'm going to try taking this route.
Just my thoughts,
WillieP.
Unfortunately that one contains propionic acid (preservative) which will likely make it unusable for fermentation. So I've read here anyways.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
Irishgnome
Irishgnome wrote:Here you go: viewtopic.php?f=3&t=58570
Cheers
Expat take a look at my link above, apparently the preservative is okay.
Cheers.
Expat
Post by Expat »
Cheers
Cheers.
Fair enough!
EXPAT
___________________
