It did not turn out as well as I had hoped. I was attempting to Butter it as well.
here is the topic..... viewtopic.php?f=101&t=71482
Long story short It ended up with some "strange" off flavor.
The flavor is spread through entire run. I proofed every jar individually. I am assuming that it is an Ester of some kind.
It has the taste (and slight smell) of Pineapple/Model Glue. It is VERY unappealing....
I asked a friend that owns an Artisan Distillery to check it out,, he originally thought it was "over proof" & was surprised when he checked it with his P&T that it was 80proof...he was expecting 120 or higher.
I am getting ready to do another Rum. I am planning on using the same recipe ShineOn's Rum viewtopic.php?f=101&t=70778 I am NOT planning on trying to Butter this one. I am going to just let it ferment, then run it "normally".
I am trying to decide If I want to:
1}.. add the previous distillate with the new batch in the boiler.
2}.. Take previous distillate add water to get about 7 gallons of Wash & rerun.
3}.. After running New batch let Dunder cool to room Temp add first Distillate then re-run.
4}.. Chalk first batch as a learning experience & "let it go.......down the drain"
Thanks in advance.....
hs9
