Hey all, I know this is a bit of a weird thing to get excited about, but I just tried out a new heating element and I'm quite impressed. I use a 220v 5500w element to run my boiler and I've used probably a dozen different elements over the years. Once they start to get ugly, I usually retire them, so as to avoid any type of scorching problem. I did my second (of 3) run on my new bourbon recipe with this thing and it looks exactly the same as it did before I ran it. I'm impressed... even after 1 use my elements get a bit rough looking, even when I use ultra low watt density.
This is the one I used: Dernord 240V 5500W Immersion Ripple Foldback Brewing Water Tubular Heater Element with 1 Inch NPSM Thread White
It was $29.99 on amazon.
Looks like brand new, still. So, is there anyone else out there that has an element they are impressed with enough to mention it?
I'm sure this has been covered in the past, but I've been out of the loop for quite a while. Even if you have an element you dislike, post it up so I know what to avoid. Although, this might be the only element I use from now on.
Caveat: it is made in China
