Angel's share
20literpotstill
Angel's share
Post by 20literpotstill »
I've been using the smaller 5 litre charred oak barrels to age my corn whiskey and single malt barley recipes, but I lose about 50% or more the first year. I've soaked the barrels inside and out for 48 hours, even drove the stave rings closer to center. In March 2018 I put up 5 litres of 70% Scots, and yesterday checked the proof. There were only 2.15 litres but the proof was 186! The angels only got water! I added 2.8 liters of distilled water to fill the barrel, which dropped my proof to 80. Is this typical? I was hoping to store it in the barrel for 5 years, but I don't want to add water again. I've had similar results in my corn whiskey as well. Maybe 5 litres is just too small a barrel to start with? Any ideas would be greatly appreciated.
Swedish Pride
Re: Angel's share
Post by Swedish Pride »
yes the barrel is too small to store for 5 years.
sounds like your experience is typical of the loss you get with smaller barrels
Don't be a dick
fizzix
Re: Angel's share
Post by fizzix »
One year is my maximum for my 3-liter and 5-liter barrels.
The confines of these smaller casks allows greater wood contact with the liquor.
And as you say, the Angels' share gets ridiculous beyond that time.
Re: Angel's share
I copied this from “The Angel’s Share” by Oak Barrels Ltd.:
Using a smaller sized barrel changes the amount of surface area or the amount of wood barrel in contact with the contents. This larger ratio of wood to liquor has a direct impact on the flavor and length of the aging process and is the very reason that aging in a smaller barrel is much faster. For example, liquor can be aged out in four to six months when aged inside of a 20 L barrel instead of years and years using the standard large 53-59 gallon barrel.
The rule of thumb for aging in smaller barrels:
—> 20 L Oak Barrel – four to six months
—> 10 L Oak Barrel – two to four months
—> 5 L Oak Barrel – four to six weeks
—> 2 L Oak Barrel – two to four weeks
—> 1 L Oak Barrel - one to two weeks
Hope this helps.
20literpotstill
Re: Angel's share
That's incredible new knowledge to me, thanks!
seamusm53
Re: Angel's share
Post by seamusm53 »
Big players with 55 gallon barrels don't bother but can't hobbyists slow the angel share loss - I know, angering angels is probably unwise - but coating the outside with wax - wrapping the barrel in plastic - anything to slow evaporative loss. Couldn't this help? I have a 5 gal barrel stored in multiple trash bags hoping to accomplish this. Can't hurt IMO.
OtisT
Re: Angel's share
Post by OtisT »
seamusm53 wrote:Big players with 55 gallon barrels don't bother but can't hobbyists slow the angel share loss - I know, angering angels is probably unwise - but coating the outside with wax - wrapping the barrel in plastic - anything to slow evaporative loss. Couldn't this help? I have a 5 gal barrel stored in multiple trash bags hoping to accomplish this. Can't hurt IMO.
Yes, hobbyists can accomplish this and just one way is by using a proper barrel for small volume long term aging.
Badmotivator style barrels are a bit stingy with the angle’s share and are great for long term aging of small volumes. They are made of a stainless steel pan with an oak barrel head pressed into the end.
2 gallon Badmo with spigot
The Badmo barrel’s wood surface area to volume ratio are relatively close to that of a 55 gallon barrel, a bit lower. The barrel head is the same thickness as a big barrel, so breathing is similar to the big barrels.
Badmotivator is a member here on HD and he came up with the idea and has a great thread that shows the evolution of making them. I’ve made dozens myself from 1 to 3 gallons in size and I love them.
Here is Badmo’s original thread. viewtopic.php?f=4&t=60032
He also has a great u-tube channel under the same name that shows each of his construction steps in video. Very cool stuff.
Otis
Oldvine Zin
Re: Angel's share
Post by Oldvine Zin »
What I have found in my aging environment (basement in Seattle) is in a 1 gal barrel I loose about 50% in 2 years, in my 5 gal barrels I loose about a half gal in 2 years. Loving the 5 gal barrels and looking forwards to try some 10's
OVZ
Oldvine Zin
Re: Angel's share
Draining a 5 gal barrel of HBB, hoping to get at least 4.5 gals out
OVZ
Expat
Re: Angel's share
Post by Expat »
Oldvine Zin wrote:Draining a 5 gal barrel of HBB, hoping to get at least 4.5 gals out
OVZ
Looks identical to the barrel i'm using :) Really making me look forward to the day when i'll be pulling my AG :-) Only 1 month in so far.
Two years seems the sweet point from what I see. Question, was it a new barrel or previously filled when you started?
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
Oldvine Zin
Re: Angel's share
It was a fresh Gibbs and yes two years in the 5 gal gives me the flavor profile that I like. Next fill will be a rum.
OVZ
