Vapor Management Question
minime
Post by minime »
I'm finally starting to build a 3" VM column. In Riku's new book Designing and Building Automatic Stills he shows an elbow turned down into the vapor path inside the column rather than relying on EVDP. I would think this is more akin to stream splitting than the traditional "alcohol vapor is heavier and sinks" method.
Any of you fellows running VM columns tried this new innovation??
This topic has 168 more replies
Register Login
