Need Help With Custom Burner Tube Coil
All things related to oils and Hydrosols. How to make them and their uses.
FreeStilly2
Post by FreeStilly2 »
Researching how I can build this custom burner I need. This is actually for dry distilling birch bark which I make Birch tar oil out of.
Here is the barrel I will most likely use:
https://www.grainger.ca/en/product/p/GW ... 4242700251!
Now I need to build a tube type burner that will circle around that starting at bottom and coiling around until a few inches under the top. I normally distill in something smaller and build a fire around it, takes about 45 to 60 minutes with a nice hot fire. Moving to this bigger barrell is going to take a whole bunch of wood so I am thinking propane might be more efficient.
Any of you made anything like this or know where I can start sourcing parts for it? I am in Canada so either Canada or USA preferred. I would think this will probably require a 100lb tank as well?
acfixer69
Re: Need Help With Custom Burner Tube Coil
Post by acfixer69 »
I would copy this or probably just buy this one https://www.blichmannengineering.com/he ... urner.html
