PLASTIC EZ Filter system
I have the system used it a dozen times the point of filtering through carbon with this system is you cant use it above 70% anyway . above 70% it falls right past the carbon as the particles are to small to interact hence why the same volume of water and ethanol has different density's , i have melted acrylic plastic with my first run at 94% a lesson i quickly learned , just water down your product before running it through the ez filter i set mine to around 42% and run around 9 litres just leave it in there over night never had a problem yet , i made my own neoprene re useable washers and there is still no melting or flavour in the product and neoprene stinks !
Re: PLASTIC EZ Filter system
Please read rule " I " from the following link https://homedistiller.org/forum/app.php/rules .......for that matter read all of the rules while you are there.
Plastics use will NOT be tolerated on this forum.
