GFCI - oh my goodness... The sticker shock.
If it plugs in, post it here.
tiramisu
Post by tiramisu »
I just priced out a NAGF230 - Federal Pioneer 30 Amp Double Pole GFCI Circuit Breaker
$647.70 CAD.... I realize that is only $500 in real dollars but it is a big-ticket item for me.
What are you guys doing in your home to keep from killing yourself with a short?
Thanks,
t.
StillerBoy
Re: GFCI - oh my goodness... The sticker shock.
Post by StillerBoy »
tiramisu wrote: Sat Mar 20, 2021 4:04 pm What are you guys doing in your home to keep from killing yourself with a short?
Running on properly wired setup.. regular wire size and breaker for the task..
A GFCI is not a requirement for operation of a still..
Mars
– Albert Einstein
In case everything else fails, my still has an earth strap connected to a pipe in the ground.
KSpirits75
Post by KSpirits75 »
Why this gfci? If it's what your circuit panel takes, you can always install a regular 30A breaker and install a separate panel that uses inexpensive GFCI breakers.
GFCI spa panels.
Ya get a weather proof metal box with a gfci breaker already in it for around $100 :wink:
Expat
Post by Expat »
Used GFCI spa panels aren't too hard to come by, got mine for nothing and saved it from being on the road side.
You should have a GFCI, too much water around to be safe, and for your life its a basic precaution.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
nerdybrewer
Post by nerdybrewer »
I got my spa GFCI on Amazon.
240VAC 50 Amps and IIRC it was under $100.
Having the knowledge and experience to correctly hook it up, priceless!
(I was a card carrying electrician in a former life, but that was too much like work so I became a computer guy)
Cranky's spoonfeeding:
tiramisu
Post by tiramisu »
It seems odd to me that a whole subpanel assembly is less than a single branded breaker.
Thanks for the tip.
