Mistakes were made, need advice on next batch.
Posted: Wed Jul 14, 2021 4:10 am
First time making birdwatchers sugar shine, used:
90l water
20kg sugar
600g tomato paste
3 lemons
250g yeast
Mistake #1
It fermented for 12 days and we distilled it at 9.5%(the wash). I wanted to do it after 7-8 days but my partner was against it since it was still bubbling/fermenting. Temperature was consistently around 35 celsius, slightly higher on a few days.
The stripping run yielded 35l.
Mistake #2
For the second run/cut making my partner only stripped the first 2 liters. He kept everything else together. He usually does this when making schnapps since the flavor difference is minimal. So basically no heads/hearts/tails separation. Result was a meh sugar vodka, had a schnapps-like tone for me personally but he said it was fine. (I'm guessing this is due to the no separation and either the heads or tails polluting the flavor)
Mistake #3
Botanicals for maceration were as follows
500g juniper
250g coriander
25g cassia bark
25g lemongrass
25g rose blossom
5g cardamom
10g lemon and orange peel
I wanted to macerate for 24-48 hours max. We ended up macerating it for nearly 96 because of weather conditions preventing us from distilling. I didn't think about taking the bag out. The bag was kept in the pot still during distillation.
The end result is 30 liters of gin @41% . It has a strong cassia/cinnamon smell, the flavor when tasted straight/50% dilluted has a schnapps-like undertone like I said. Most of the taste is coriander and cassia, and some unknown bitterness that doesn't really taste like juniper. Sitting in a 30l demijohn right now I can still hear it bubbling very slightly for some reason.
So this is what I'm thinking for the next run:
1. Same shine recipe, distill when it reaches 8% or after 8 days no matter the %. I'm guessing 12 days is way too much for the ph levels and the temperature was consistently good so that's not a concern for off flavors.
2. Again no cuts on stripping run, do a much stricter second run, something like this:
Throw away first 2l
Collect 5l heads
collect 20l hearts
collect 5l tails
Mix heads & tails with those from last batch, use only 20l hearts for maceration.
Do you think 20l hearts is too generous? Should I collect less hearts and more heads/tails? Assuming the same 30l end yield.
3. Use Odin's recipe this time (finally)
so for 20l hearts that would be
240 grams of juniper
60 grams coriander
10 grams of lemon and orange peel
macerate 2 weeks
NO HERBS IN POT STILL THIS TIME
First cut as long as it's cloudy/the juniper oil comes out, collect everything else (we would dillute it to 30% first for the still).
So last question is for the final distillation we can let the still run all the way? AKA I don't have to stick to Odin's 400ml per 1l since our still doesn't really ever yield 80% alcohol, I can just collect it as long as alcohol comes out? Or is there going to be a large difference in flavor (even though we'd just use hearts for that third run/gin run) if I collect over that 400ml per 1 liter of neutral.
My problem with the current product we made is that the cassia/cinnamon smell and taste dominates when i drink it straight. Juniper is almost nowhere to be found, even though I used a proper ratio. I'm guessing this is because of the 96 hour maceration making the cassia far too strong, or 25 grams is way too much cassia. I guess maceration should only be done with juniper and coriander, and the rest of the botanicals can be added to the still during the run without previous maceration? The other thing is if there is another reason for the schnapps-like off flavor and the hearts taste the same I'm not sure if it's going to be worth the effort to keep trying to do this. My main goal currently is to create something in the tier of beefeater/gordons (london style, strong juniper) and after that my end goal would be to make a flowery gin (something like Hendricks Midsommer). I would definitely call this product "bad" if I bought it at a store. It's actually not that bad when mixed, gets you drunk fast and no hangover at least last night, tried it in a tom collins and need to try it with tonic to be sure 100% if it can be called decent or not. I appreciate any and all advice you guys can give me for the next run, especially for avoiding the schnapps-like taste/off flavor and getting the juniper to come through.
90l water
20kg sugar
600g tomato paste
3 lemons
250g yeast
Mistake #1
Mistake #2
Mistake #3
500g juniper
250g coriander
25g cassia bark
25g lemongrass
25g rose blossom
5g cardamom
Throw away first 2l
Collect 5l heads
collect 20l hearts
collect 5l tails
60 grams coriander
macerate 2 weeks
