This requires a bit of explanation before. There is a maceration method in alcohol of herbs / spices to produce liqueurs. There is a maceration method in alcohol, then distill for example to produce gin.
Question: Someone ever tried to distill in water or steam and then produce a liqueur, gin or other? I believe there are differences compared to maceration in alcohol ... I thought you could use all that comes out of distillation (essential oil + hydrolate) to produce alcoholic beverage (replacing the water of the recipe with hydrolate) .. thanks to all
Botanical distillation for alcoholic beverages
- Demy
Re: Botanical distillation for alcoholic beverages
Interesting idea, let me see if I understand what you are saying. You create a hydrosol without separation and then redistill by mixing it with a neutral to make say your gin thus bypassing the masceration step.
- NZChris
- Demy
Yes, right. If you want to prepare a liqueur (water, alcohol + botanists, sugar) you could try with hydrolated without separation, sugar, alcohol.
