I have done a search , but cannot find the list of what the topic icons mean
Some are self explanatory , such as the little lock , but what do the others mean
is there a locked topic which explains what they mean
ie
asterisk
scrolling
blue red
etc
etc
I do not want to know just those few as I am sure there are many
is there a list which shows what the topic icons mean
The Friendly Spirit
Re: is there a list which shows what the topic icons mean
there is a FAQ button in top right corner you can look in there..
or here is a link to the documentation..
http://www.phpbb.com/support/?sid=c8581 ... b6864144ae
cheers..
cheers..
The FAQ section does not list the icons
I will try your other site
The Friendly Spirit
I had exactly the same question. The envelope please....
black = you read it
red = new posts
moving text = active threads (about 30 posts or more)
star = you have posted there
Simple, and pretty much what you might have guessed...
black = you read it
red = new posts
no luck on the suggested siteRod wrote:The FAQ section does not list the icons
The Friendly Spirit
maybee this post can be placed in the FAQ or made into a sticky some where.
hope this helps ...
cheers..
hope this helps ...
cheers..
- Husker
Nice decoy, but the problem is, that when you change the skin, the icons change also. I switched back to subsilver, and the icons are different than what you show. but I certainly do like what you have put together in that post.
H.
H.
no probs husker..
hope it helps rod out at least..
cheers..
cheers..
