Distilling Methanol
Dropout
Distilling Methanol
Post by Dropout »
Good afternoon everyone.
Love the forum. Lots of great info.
I have a solution that is comprised of about 50% glycerol, 40% methanol and about 10% water and I need to reclaim the methanol.
Am I correct in assuming that the solution that you all start with has a much higher percentage of water and that affects the purity of the distillate? If so, what would be a reasonable purity that I could attain with a pot or reflux setup? Glycerol boils at something like 325C so the only issue will be the water.
Would all the typical calculations for column size etc still be appropriate for methanol? My plans are to use a 50 litre batch size.
Thanks in advance.
Dropout
KatoFong
Post by KatoFong »
Just out of curiosity, why are you distilling methanol?
Guest
Post by Guest »
I have a small system to make biodiesel. The byproduct contains glycerol and methanol. The methanol can be reused if it can be reclaimed.
Dropout
Yttrium
Post by Yttrium »
All the calculations for ethanol should work fairly well for methanol. Since the boiling temp of methanol is less than that of ethanol, the equations on this site will underestimate the purity of your product by a little bit.
With a reflux still, I would imagine that you should have no problem achieving 95%+ purity. If you were to distill the solution once in a pot still, you'd probably get around 75-80% purity of methanol.
The future is not set. There is no fate but what we make for ourselves. --John Conner
level Joe
Post by level Joe »
Is glycerol a sugar or an alcohol ? If its a sugar, would there be a concern of it burning to the still with only 5%+/- water left in solution? Just a question I thought I would ask to someone who might know.
Salus populi suprema est lex. [L.] The safety of the people is the highest law.
The Chemist
Post by The Chemist »
Sugars are carbohydrates. Carbohydrates are polyhydroxy aldehydes or ketones. Glycerol is a triol (polyhydroxy), but has no carbonyl (aldehyde/ketone) bit. So, glycerol (also called glycerine) is an alcohol, not a sugar.
That said, glycerol is a syrupy liquid 0.6 times as sweet as sugar (table), and boils with decomposition (burns) at 290 deg C. So, unless you're heating to 554 deg. F :shock: you should be okay.
Purposeful motion, for one so insane...
level Joe
Post by level Joe »
Thanks Chemist
The first 1/2 of that was ovar my head but the second part answered any questions.
Thanks again
Joe
