This is my controller! There are many like it, but this one is mine.
Will post just the completed pics as the wiring is simple and I pretty much followed the diagram Auber provides, with
the addition of a 30A switch inline with the mains power. Unless someone asks for pics of the guts for some reason.
I'll do my best to provide a complete build list as well with a short explanation of why I chose each item, if warranted.
I kept this build as basic as possible as I'm only using one SSR relay, one RTD thermo sensor, controller, power switch and 240V sockets.
PARTS LIST:
Thermoplastic Enclosure (8x8x4)
There's a lot of project boxes to choose from out there, in varying sizes and shapes. I knew I wanted to go plastic instead of metal
even though it meant I'd have to make sure to ground any applicable individual components to stay safe. I liked this box due to the
generous size without being *oversized*, ease of workability, liquid/weatherproof and the ability to position the feet in several different
orientations for stability where needed.
Nonmetallic Threaded Strain Relief Fitting 3/4 Inch
Auber Instruments DSPR400 Still Heat Controller
If you're not already aware, Auber makes some damn fine distilling hardware. I waffled a bit between the DSPR220 and the DSPR400 but decided to
get the DSPR400 with all the bells and whistles for the few extra bucks to future proof myself in the event I change things up. I'll be running in
*direct, manual mode only*, not using the complicated PID scheduling system at all. The manual states how to do this but it is a tad complicated,
so I may just make a short video to demonstrate how to do it later, possibly in a separate post.
40A AC SSR Relay (SRDA40)
External-Mount Heat Sink for 40A SSR
This heatsink was just perfect as I wanted to mount it externally to put the majority of heat outside the box. It is definitely overkill
for the 40A SSR relay, but that's not at all a bad thing. Holes are predrilled in the heatsink making the installation as easy as cutting out a relay sized hole
in the lid and the included screws, applying heatsink paste to the relay (I used my own; Grizzly Kryonaut), bolting the relay on and screwing the entire heatsink assembly to
the lid. Some people apply some sort of silicone around the relay hole before bolting the heatsink down to totally seal and weatherproof it; I didn't.
Waterproof Double Pole Single Throw Rocker Switch 250V 30A
This is the only change I made to the 220V wiring diagram Auber includes in their manual for the DSPR400 controller. I ran both hots straight to the OFF
blades on the switch, then (using the appropriate length and color 10 gauge wire cutoff from one of the wiring coils I bought) crimped on a smaller 16 gauge wire
to the two 10 gauge wires I then connected to the ON blades on the switch. The smaller wires are then connected to the DSPR400 so it only comes on
when the switch is toggled ON. There are several ways to do this, including not even having an ON/OFF switch, but that's how I did it. You may note that
there is no fuse or breaker installed: since I know that everything is well grounded, I trust the breaker at the mains breaker box to pop before anything
else does in the event of some catastrophic failure. I figure it's one step above what Auber feels is a safe recommended setup, so feeling good about it.
240V 30A NEMA L6-30R Socket
There are many ways to skin a cat here in terms of power hookup, but I went with the three prong, locking socket system. Mainly because
the wiring loops (see below) I wanted had these sockets on them... very happy with the quality, fit and satisfying positive lock.
Cable, 10/3 Extension Cord TEN FEET (10') Nema L6-30 Male and Female
Cable, 15ft 10/3 Cord with NEMA L6-30P Locking Plug
You'll note the 10' cable product has one side with no plug; I cut approximately 2' off that end to wire the whole project up with, leaving me with 8' of cable
to the box, then the 15' cable to go to the element. Worked out very nicely!
Tri-Clamp Liquid tight RTD Sensor, for 2" pipe
Lots of options for RTD thermo sensors; I chose 2" triclover, 6" long with the '12 ft Braided Cable with XLRCON-M connector/cable' option. Random color: I got yellow.
Very happy with it... connecting the cable to the sensor is heaven and having the option of disconnecting it from the box is so worth the extra effort and dollars.
Heating Element, 5500 watt (240 Volts) 1.5" TC INTEGRATED Ripple V2
I cannot recommend going triclover enough for an element. Makes cleaning the keg and overall handling much easier, as well as having the ground integrated
into the triclover metal, so just attaching it to your pot/keggle automatically grounds it. So long as you have your ground wire hooked up to a proper ground...
you *did* ground everything correctly, right?
Anyways, that's pretty much it. Let me know if you have any questions or concerns. Pretty straightforward and plain Jane but drives an element with
the best of 'em! I had fun building it the way I wanted it and highly recommend it over a prebuilt for those who feel they have a strong enough handle
on working with their hands/tools/electricity.
