Canadian Snowflake Vodka
I didn't want to divert X7's thread in Column design any further so I guess I'll bring it here. Canadian Snowflake Vodka sounds like a noble and challenging pursuit. In addition to discussing the distillation processes, what other tricks are out there? While I think the neutral I make now is pretty good, experimenting to make it better sounds like fun; this is a hobby after all.
2" Bokmini, VM and potstill heads
7.75gal. & 15.5gal electric boilers
Re: Canadian Snowflake Vodka
There's pure and then there's pure. Just over a year ago I made a batch of Wineo's plain old sugar wash @ 6% ABV. Striped it and then refluxed it on my 42 inch offset to dead neutral. Pretty amazing stuff but I like a little flavor and even add a little bit of late heads to my hooch.maoule wrote:I didn't want to divert X7's thread in Column design any further so I guess I'll bring it here. Canadian Snowflake Vodka sounds like a noble and challenging pursuit. In addition to discussing the distillation processes, what other tricks are out there? While I think the neutral I make now is pretty good, experimenting to make it better sounds like fun; this is a hobby after all.
If you want to go for the best neutral, you just can't beat it. IMO
Was the 6% wash intentional for extra neutral or just what you normally make your WPOSW? Did you do anything special during stripping; run extra slow for the spirit run?
Activated Carbon?maoule wrote: In addition to discussing the distillation processes, what other tricks are out there?
Too much of a hassle unless absolutely necessary.zymos wrote:Activated Carbon?maoule wrote: In addition to discussing the distillation processes, what other tricks are out there?
With a batch still, there should never be a reason to use carbon filtering.
I managed to get one of my early runs to where it tasted like distilled water. Since I don't drink for effect, but rather for taste, didn't try to follow that path again.
A nobel goal, if that is what you are after.
Low ABV washes give very clean ferments. Rack and clear before stripping. Run reflux ratio @ 9 or 10 or higher if time permits and you'll have the most neutral product you can imagine. (Scary actually) No need for carbon or airing or aging!maoule wrote:Was the 6% wash intentional for extra neutral or just what you normally make your WPOSW? Did you do anything special during stripping; run extra slow for the spirit run?
JustNotMyCupOfTeaMinime
Wow I need to watch what I post about
but seriously, this has always been my pursuit along with bourbon and rum.
I visualize the fractions in a reflux still of whatever kind as being stacked. The goal for snowflake vodka is to reflux it long enough to get most of the heads in the whole boiler to the top of the column. I usually wait 2 hours at full reflux. The to not disturb the fractions anymore than needed, pull the heads off really slow. 1 to 2 drops a second is about right regardless of the column size.
Now the trick. Since the parts of the heads that are going to show up in diluted vodka are hard to detect in high proof, you need to water it down to smell and taste. Even foreshots can be diluted just remember to spit. Once you get past the heads you will know it. All of a sudden there is no smell other than ethanol, an the taste is slightly citrus like with no aftertaste, and for experienced alcohol drinkers, no burn at all at 40%.
You can speed it up a bit once you get to the hearts. I know a few haven't cared about the reflux ratio but this is a handy thing to know in order to not have to keep fiddling with your setup. First of all you have to know what your max throughput is with no reflux, without flooding the column. Usually you want to run the power to the point where the temp is just over the neutral temperature with no reflux. 3 to 4 degrees c should be sufficient. Collect a fixed amount and measure the time if you have a column that is capable of operating in this mode. Once you know this rate it is easier to set the constant rate for the hearts.
Generally 95% drips with 20 drops per ml (correct me if you know better) so if you collect 10 ml/minute that is 200 drops. This is pretty slow which is .6L/hour but this is an example. You have to measure your own rates.
If you reflux 100% then you are returning 10 ml/minute to the column. The best stuff I make is usually refluxed at 9:1 for every 9 ml refluxed you collect 1 ml. or 20 drops / minute. There is no need for a higher percentage because you don't gain much ground for the lost of time.
If you know with some but of accuracy what your starting volume and percent alcohol were, you can calculate when you are 80% finished. This is a good time to start looking for tails. Tails show up when you start tasting the original flavor of your wash or any other off flavor. Yes it is handy to know what your wash tastes like and that is the first hint of tails.
The average pot still running at about 2500 watts makes about 4L /hour. So if your column is making 400 ml an hour with 2500 watts you are in the ballpark. Of course this would be a hard thing to have to tend if you have a finicky column like a tall thin one or one which changes drastically with the slightest breeze. Insulation on the boiler and column help finicky columns.
Now lets talk about practicality. I have stripped enough to fill my 58 L boiler with 54 L of 45%.
This is the equivalent of 27L at 95%. so lets say we take 2 hours for stacking the fractions. another hour for removing heads. collecting 20L of hearts at .5L/hour. and running out the tails if you choose to for rerunning. his is a 50 hour run.
and 20L(5 gallons) of neutral. I hope you have a lot of thirsty mates. This is 66 750ml bottles of 40%. need I say this isn't very practical. So start small with just enough to operate and learn the feel. A 5L 45% will get you 5 or 6 bottles, and only take a while to run. You will stack heads for 2 hours run heads for another 20 minutes and collect hearts for 4 hours. This is more practical. Just make sure your element is on the very bottom of your boiler if you have internal electric heat.
Excellent info guys! Shit, I thought I knew what patience was already. Anybody got a copy of War and Peace I can borrow for this weekend?
Pinto Cheers for the refresher info, will be doing this tonight or tomorrow day..... a good book is recommended, learning a language even!
My wash was about 8% and the pot stilled stuff tasted pretty good considering there were no cuts! Hint of lemon coming through. I used Winoes receipe
About 15l-20l of 45% so, ~6L of 95%, which again is like 12 Litre botles of vodka! Probably going to end up running this thing ones a quarter!
I wish you luck Maoule!
Been Stilling since October 2007
I operate a 20ltr, 2m LM Reflux Still, based on the Bokmini Photos http://s391.photobucket.com/albums/oo358/ZAXBYC/
I use the head part of this unit for stripping and as a Pot Still- produces LOTS of flavour
