Aaaaand I'm a moron...
- bcook608
So this is DEFINITELY a "what not to do" moment.
Please refrain from any harassment or negative comments, I already know how lucky I just got.
This is a public service announcement. Don't let your excitement get the best of you. I got caught up in the excitement with my new equipment for upgrading my controller to 240v. I plugged in the cord and measured out the length I needed to run into my bedroom so I could cut it to the right length. You can probably guess what happened...
Boom!
Yupp, like I said, I'm a fucking moron...
I'm done building for a bit...
And I need a drink... A big one...
Boom!
- Site Admin
Re: Aaaaand I'm a moron...
I'm glad you're ok.
Enjoy the adrenaline rush.
- bcook608
Thanks. Got a nice little lightning burn on my thigh to remember it by...
- Deplorable
You are very lucky that's all you got.
We all do stupid things from time to time. Like pick up a slab of dry ice with your bare fingers. Yeah, I just did that. Fortunately, I realized how stupid that was and very quickly set it back down.
WOW! that was a close call.
- elbono
That's called an arc flash explosion in the trade. I've lost a couple of screwdrivers in similar fashion.
We're your ears ringing? Some people need to put in ear plugs when doing electrical work! All depends on the size of the breaker. I used to work with stuff fed from a 2000 kva transformer. Here's the garb we wore for working inside the main panel:
And yes I'm wearing earplugs inside there.
Luckily residential feeds are small enough it's fairly hard to kill yourself at home even though it's possible and you can definitely need to change your skivvies if you aren't careful.
I bet you make sure the breaker is off from now on.
- bcook608
Yeah, I set the cord down pretty quickly too. Unfortunately it didn't make a damn bit of differenceDeplorable wrote: ↑Sun Dec 04, 2022 2:49 pmYou are very lucky that's all you got.
- bcook608
LOL if I'm doing anything like this again it'll be in the garage on the opposite wall from ANY outlets.. Just to be safe...elbono wrote: ↑Sun Dec 04, 2022 3:00 pm That's called an arc flash explosion in the trade. I've lost a couple of screwdrivers in similar fashion.
- Stonecutter
Well now that just takes all the fun out of it!
Close call. Glad you’re ok
-Thomas Paine
-Thomas Paine
Wow. Close call. That's definitely a good way to ruin a pair of snips.
Been there, done that. Just not with that many volts.
Better make it a double.
I always say, anything like that you walk way from with all your human parts working can be chalked up to a learning experience.
Very glad you are ok and all your parts still work. Looks like you were cutting across your knee…. Bet you’re glad it wasn’t your lap!
That’s it. No more reading!
- HDNB
heh heh. i often use a new pair of line pliers to "test" a breaker. always leaves a nice little burned hole in the cutting blade that is perfect for stripping wire.
Never done it on a 240 line though. i'll bet that was bright! (the resulting light, not the action itself) LOL
glad you survived, shorting them is one thing.... coulda been really nasty/deadly if you got hooked into a line direct with a ground on the other end of your body.
gotta know though. did the breaker work?
now i drink for evil.
- bcook608
It sure did! Lit up like a firework and sounded like a gun went off!HDNB wrote: ↑Sun Dec 04, 2022 5:09 pm heh heh. i often use a new pair of line pliers to "test" a breaker. always leaves a nice little burned hole in the cutting blade that is perfect for stripping wire.
Breaker tripped immediately, thank the electrical gods.
- bcook608
It arced about 6-8" to my thigh. I was using both hands cutting ABOVE my lap. Just glad it landed on the 2nd leg instead of the thirdDougmatt wrote: ↑Sun Dec 04, 2022 4:57 pm I always say, anything like that you walk way from with all your human parts working can be chalked up to a learning experience.
Very glad you are ok and all your parts still work. Looks like you were cutting across your knee…. Bet you’re glad it wasn’t your lap!![]()
- rubberduck71
You might have been before the "earth shattering kabooom"
But now you've been educated.
I have 440v 3ph. in my shop and have made modifications to the existing circuits.
Mistakes are just out of the question.
Turn off the power and lock it out.
- IAmPistolPete
I've been knocked off a ladder more than a few times retrofitting live 277V fixtures. Takes a good 1/2hr to get your legs back. I blame that for my bald spots, not my age.
If you ever find yourself being chased by a pack of wild taxidermists, do not play dead.
They have changed the NEC rules.IAmPistolPete wrote: ↑Sun Dec 04, 2022 8:00 pm
Part XII Special Provisions for Electric-Discharge Lighting System of 1000 Volts or Less includes 410.130(G) Disconnecting Means.
Now each light has a small connector you can unplug.
- Attachments
- 15b_RHunterPH6.jpg (14.99 KiB) Viewed 4794 times
- IAmPistolPete
They were all government & public school buildings, so codes did not apply
- NZChris
A mate of mine made himself a new 240V extension lead and put male plugs on both ends, he discovered his mistake when he grabbed the plug
- NZChris
We have even funnier stories that we could tell you about each other.
The house electrician at the university venue I used to work at, told us the story of a touring lighting tech who had a set of "tails" made up. At one end was a 63A 3-phase CEEForm connector. At the other, a set of 13A (UK) plugs, all wired in parallel. In venues without a genuine 63A 3-phase supply, he would simply run each of the plugs into a different wall socket in order to spread the load from his lighting rig. He also had the matching female version (a board with three lines of 13A sockets connected to a male 63A 3-phase CEEForm, into which he plugged the "tails" when the house supply was available!). The in-house sparky, listened politely to the proud explanation and without saying word, took out a pair of wire cutters and cut off all the 13A plugs.
To the OP: Lesson learnt then? The problem with electricity is there's no warning until it's too late. If something is hot you can feel the heat before you touch it. On my one or two occasions of being shocked, I found a good run while swearing lots helped to run off the adrenaline.
- bcook608
Lesson DEFINITELY learned! I didn't go for a run because I'm fat and lazy, but I paced the house for a good 30 minutes just repeating "what the fuck! That was sooo stupid! Holy shit!" all while listening to my wife ask if I needed the short bus for the special kids because that was fucking retarded.NormandieStill wrote: ↑Mon Dec 05, 2022 5:11 amThe house electrician at the university venue I used to work at, told us the story of a touring lighting tech who had a set of "tails" made up. At one end was a 63A 3-phase CEEForm connector. At the other, a set of 13A (UK) plugs, all wired in parallel. In venues without a genuine 63A 3-phase supply, he would simply run each of the plugs into a different wall socket in order to spread the load from his lighting rig. He also had the matching female version (a board with three lines of 13A sockets connected to a male 63A 3-phase CEEForm, into which he plugged the "tails" when the house supply was available!). The in-house sparky, listened politely to the proud explanation and without saying word, took out a pair of wire cutters and cut off all the 13A plugs.
*no offense intended, we reserve the R word for when we REALLY need to drive home a point and I definitely deserved that one
Welcome to the group! We are a majority now!!!
Dude! You’re so lucky. That’s some serious power you just harnessed! We’ve all been there in some way. Brain farts happen.
I’ve definitely gotten a little thrill from working with 110V, being cocky and not turning off the breaker. I installed new power outlets in my basement and the previous owners did not install them up to code. There was not enough slack in the wire and I arced it with a screwdriver while fussing with the old outlet. Gave me some nice flash burn in my eye. Lesson learned.
Been there, done that as well.
I saved the "unintentionally modified" side cutters as a reminder.
Glad You are OK.
Glad You are OK.
