Oops - what happened to my sugar wash? (Pics)
Chug
Post by Chug »
Uh, never had this happen before. 15 gal wash (Shady’s), left it unattended for a few weeks with an immersion heater. Went back today, my stilling shed smells sour and all this thick off-white goop was on the top. Read 1.04, so clearly not fermenting anymore. I dumped it, but what happened with this batch? Pic attached.
5 gal homemade potstill -:- If it works, it ain’t stupid -:- Progress, not perfection
Ben
Re: Oops - what happened to my sugar wash? (Pics)
Post by Ben »
Sour like vinegar, or sour like sourdough?
Chug
Post by Chug »
Unpleasant sour. Like vinegar. Definitely not the pleasant sour of yeast.
Archee72
Post by Archee72 »
Maybe you pitched the yeast into too hot a wash? Around the 35*C is best I’ve read? As Shady says.. “don’t stress the yeast”
Vinegar requires oxygen.
How and why did you let oxygen get to it while it was fermenting?
SDEngr1
Post by SDEngr1 »
Any mash or wash is extremely susceptible to infection from wild molds, yeasts, etc. even if things are initially well sterilized. Idle time will allow them to propagate.
Stonecutter
Post by Stonecutter »
Chug do you have a picture of your immersion heater?
-Thomas Paine
NZChris wrote: Sun Dec 18, 2022 3:48 pm Vinegar requires oxygen.
Fermenting in a wooden barrel and let it set for few weeks after it was done.
Probably left the shell grit in also, that caused the pH to rise enough to make bacteria happy.
Chug
Post by Chug »
Stonecutter wrote: Sun Dec 18, 2022 4:36 pm Chug do you have a picture of your immersion heater?
Yep. Much like this one. I think it’s the Top Fin 200W model.
Stonecutter
Those finns on the end are suspect for bacterial growth. If possible I would ditch that heater for an external one of some sort.
-Thomas Paine
Chug
Post by Chug »
Stonecutter wrote: Sun Dec 18, 2022 5:51 pm Those finns on the end are suspect for bacterial growth. If possible I would ditch that heater for an external one of some sort.
I do have a square pad heater below it, but in the Great White North I need a bit more to compensate for heat loss. I gave the whole immersion heater a good dousing in some old 25% rum tails I had bottled in the shed so we’ll see.
Chug
Post by Chug »
Chris, that’s a good question. I honestly ignored this batch for the most part, but I did notice that the ferment stalled early on (day 1) so I gave it a bit of a stir and tossed in another handful of yeast to try and kick start it. That may have been my undoing.
Also, because the temps have dipped in this area lately, I wonder if the temp dropped enough to kill the yeast and then it warmed back up. I was out of the country for a few days and it’s possible the GFCI triggered while I was away, because when I returned the Christmas lights were out so I reset the GFCI, which is also what the stilling shed runs on. Didn’t think about that until now.
Stonecutter
Chug wrote: Sun Dec 18, 2022 6:23 pm it’s possible the GFCI triggered while I was away, because when I returned the Christmas lights were out so I reset the GFCI, which is also what the stilling shed runs on. Didn’t think about that until now.
-Thomas Paine
Stonecutter
Chug wrote: Sun Dec 18, 2022 6:17 pm
If there are plastic pieces on your heater I would try to use Starsan instead of dousing in alcohol.
-Thomas Paine
Those heaters only heat above the element, so it’s possible that the yeast bed wasn’t getting heated.
Since the GFI tripped, there's a possibility the heater was electrocuting the yeast.
cob
Post by cob »
Chug wrote: Sun Dec 18, 2022 6:23 pm because the temps have dipped in this area lately, I wonder if the temp dropped enough to kill the yeast and then it warmed back up.
Freezing will not kill yeast. The colder it gets the slower it works. Freezing is an accepted long term storage method.
I suspect that the yeast would have survived possible electrocution, but would have been cold when the power went back on. Because the wash has already been dumped, we can never know for sure if the yeast bed was at a lower temperature than the wash above the element, but it is highly likely.
To diagnose something, (and to fix something), you need to have all of the facts available. Pouring a cockup down the drain is the worst thing to do when you want answers for how not to repeat the mistake.
cob wrote: Sun Dec 18, 2022 9:21 pm Freezing will not kill yeast. The colder it gets the slower it works
Very true Cob ,bread yeast will work away happily at very low temps.....just much much slower.
shadylane wrote: Sun Dec 18, 2022 5:15 pm Fermenting in a wooden barrel and let it set for few weeks after it was done.
Gotta be close to the perfect way to get a result like that.
Here's my tricks to success.
Apply controlled heat to the bottom of the fermenter and have a drain down low on the side.
That way the finished wash can be removed and the trub left behind. :ewink:
I'd like to know how many things were done wrong. I suspect that the list is quite long and includes advice gleaned from forums and Youtube.
NZChris wrote: Sun Dec 18, 2022 10:42 pm ….. I suspect that the list is quite long and includes advice gleaned from forums and Youtube.
Chris I have seen you say this more than a few times .
What forums do you mean or refer to ? …. is this one of them ?
Chug
Post by Chug »
NZChris wrote: Sun Dec 18, 2022 10:42 pm I'd like to know how many things were done wrong. I suspect that the list is quite long and includes advice gleaned from forums and Youtube.
So there’s probably a list (but not from forums or YT, I use HD as my only source of truth)
- Most likely too hot. I suspect the shed space heater was on most of the time I was away without my knowledge and it gets up to 95°F in there, so that’s one.
- Most likely left it too long after it was done. I don’t use an airlock on my large fermenter so there’s a great possibility oxygen came to join the after party.
- A possible temperature crash when the power was off for a day or more
- Temperature differential - probably not too likely, as I have a constant 82°F heating pad underneath to ward off cold floors and the top of the wash is just an inch over the top of the immersion heater.
- pH - I wanted to check the pH when I saw the mess but my meter had died somehow (argh!)
- Probably should have diagnosed things the first time it stalled instead of just chucking more yeast on top.
In any case, when there are enough uncontrolled variables in any situation, sometimes I feel it’s best to say “Those things? Don’t do them again” instead of trying to tease out all of the possible variants and repercussions, and just start over.
Dancing4dan
Post by Dancing4dan »
Hey Chug, 25% ABC isn’t high enough to sanitize with. Use 80% ABV after physically cleaning to remove all residue. StarSan is a better choice. Again the item must be physically scrubbed clean first.
Marcus Aurelius
squigglefunk
Post by squigglefunk »
I think a white cat fell in and dissolved
Yummyrum wrote: Mon Dec 19, 2022 2:23 am
Like most forums, less than stellar info sometimes gets posted and AFAIK, never gets deleted. If the reader is lucky, someone will have posted a better solution, and then they have to choose what to do.
Misuse of aquarium heaters in fermenters is common advice even though people report failures. viewtopic.php?f=89&t=84932
