Butyric acid supplement
Howdy all,
I've been searching and searching but can't find the thread I originally saw this used in...
If you know the thread and can link me to it, or if you're the dude that used it can you let me know what quantities you tried? I've added them into spirit runs and thumper with high wines and can't taste or small any appreciable difference. My guess is that I'm just not using enough, but I don't want to go to far and ruin a batch.
I appreciate the help,
B
B
- HDNB
Re: Butyric acid supplement
curious, since you are using them...do they smell like vomit?
now i drink for evil.
Not really, I also tried mixing it with high proof heads and high tails and I dont really notice any interesting smells.
May just have to get lab grade and go that way. I suspect the supplements are just too low in active ingredients to make a difference.
Is hydrochloric acid the same like table salt?
So perhaps calcium magnesium butyrate is not the same like butyric acid?
Its possible, I'm no chemist
I can suggest an alternative source for it if that helps at all?
In the UK in the specimen carp angling world, we use N Butyric acid as an "Attractor" in bait so you can buy it from fishing bait suppliers.
Yes, it smells like vomit.
Thanks man, I just saw this but didn't know what that "n" meant so i was going avoid it.
I'm very confident that it's an alternate naming thing in different industries, as the chemical formula appears to be the same for all the variously named versions.
I've also bought it as butanoic.
Synonym
butyric acid, n-butyric acid, n-butanoic acid, propylformic acid, ethylacetic acid, butanic acid, 1-propanecarboxylic acid, butyrate, 1-butyric acid, buttersaeure
Thanks, that makes sense!
I appreciate it.
I appreciate it.
Very welcome.
Just go really careful with the stuff.
I got some under my nails/in my skin once and the Mrs wouldn't come near me for days!
It's really not good for the sex life!
Maybe they are probiotics that produce Butyric acid?? If so, pitch into your fermenter after the yeast have competed the lag phase.
- Tōtōchtin
- Member
Found this in my outbox. Didn't know how to forward it.
You can get reagent grade for 30 bucks 100ml or 1000ml for 70. If you can buy a liter for 70 and split it up with a few people it makes it worthwhile to play with.
Tōtō
Tōtō
Si vis pacem, para bellum
Thanks, I found some and have actually had really good results playing with it.
Edit to add link to post:
viewtopic.php?p=7755919&hilit=Pure+acids#p7755919
