Yummy’s Steam generator
Finally gathering bits an pieces .
Originally then we lived down in NSW and I distilled outdoors , I was going to make a gas fired Steam genny but as I am now in Sunny Queensland and about to have a Solar electric upgrade , I figured might as well be using some of that power . And I am distilling inside ( too many nosey neighbours .) :crazy:
Anyway , I only have a 40amp line to the shed and have a 32amp circuit to the stilling area . So allowing a bit of derating and a bit left for pumps and stuff , I bought a 6kw element . I think that will do me for what I want .
Would have loved more , but it is what it is .
I have had a short length of 3” for nearly 10 years so figured it was time to use it .
I also was going to go mechanical float valve in my original gas power idea to maintain level in boiler but have decided to follow the pack and go electric float valve and solenoid operated fill valve .
I ordered a 2” sightglass but somehow ended up with 1.5” . I couldn’t be stuffed sending it back so I’ll deal with it although it’s going to be a bit of a tight squeeze in there for the float switch .
I got a dual float switch . Top float will operate level solenoid while bottom one is to stop power to element before the chamber fills and iff’n the level drops because of a solenoid or water supply failure . Maybe might also use the bottom float with a second Solenoid valve for quick fill before switching to top solenoid for trickle fill .
Well thats the plan .
So I’m playing with my float switches and they are not smooth . Like as I slide them up and down , they feel like they are not gliding . Then I notice that they can catch on the groove where the C-clip is .
Cheap and from Ali-express they are .
(I’m now thinking I should have spent a few dollars and git better quality .)
So I pull off the C-clips and give the ends of the floats a deburr with a pair of pliers ( cause that was the first thing I laid my hands on)
That seems to have fixed them and they now slide smooth and don’t catch on the groove .
I did note that there is a small divot in the top of both floats . I guess there must be an up and down side to them. ….. maybe something to do with the magnet in them that operates the reed switch.
So I have question .
What is a reasonable headspace in a steam generator like this ? I mean hieght of water above element and some head space ?
I realise it will be a boiling fury in there , but what has worked ?
This topic has 49 more replies
Register Login
