Easy flange making tool
Make your own flange quickly
No welding Use the crack ground into the wrench to roll out the metal.
When you get it shaped hammer it level and a lite sanding on a flat surface will square it up.
Easy peasy.15 minute job
Last edited by dukethebeagle120 on Wed Apr 03, 2024 4:58 pm, edited 2 times in total.
- 6 Row Joe
Re: Easy flange making tool
I don't see much of value here.
I can't figure how to post more pics
- Dancing4dan
I do! I get exactly what he is doing. Great idea.
Heat the end 3/8 of the tubing till dull red, let it cool and that modified wrench can be used to turn a flange for making a tri clamp connection. It would work without annealing the copper but annealing it will make it easier to stretch.
Marcus Aurelius
Marcus Aurelius
I been doin these for a long time.Dancing4dan wrote: ↑Wed Apr 03, 2024 4:59 pmI do! I get exactly what he is doing. Great idea.
A little filing and they look great
I do em cold with little effort.
Use a cutting grinding wheel to cut a thin slit the width of the flange and you get a perfect width flange all the way around
I remember seeing that idea on here maybe about 10 years ago .
I tried it but I tore the copper trying to go too far in one go . Found I needed to bend maybe 20-30° and flare all around , then go another 20-30° for the next flare etc until it was at 90° .
I also annealed it first …. Easier on the wrists
I did mine with a wooden clamp jig I made, and a ball pein hammer.
It works well but it's s noisy!
The hardness of my 2.5" would have definitely needed annealing if I tried the suggested way, but if I ever need to do another flange I'll try it, nice one duke.
When you roll the lip your only taking the width of the flange.MooseMan wrote: ↑Wed Apr 03, 2024 9:51 pm I did mine with a wooden clamp jig I made, and a ball pein hammer.
So it may seem stiff ,but it's really not.
The pipe shown was the. Heavey guage copper and I did it with little effort.
Once rolled you take a hammer and a flat surface and peen out the high spots.
Takes 10-15 minutes in all but save's in waiting for flanges in your builds
I little filing to make it "Purdy" then your off again.
Dunno if he's still around,but stillerboy showed me some pretty good tricks on here a few years ago.
No. Unfortunately I don't think we will be hearing from Stillerboy again. Last time we talked he told me he felt his time was better spent elsewhere. He helped me immensely and I'm sure many others. I personally will miss him.dukethebeagle120 wrote: ↑Thu Apr 04, 2024 2:36 amWhen you roll the lip your only taking the width of the flange.MooseMan wrote: ↑Wed Apr 03, 2024 9:51 pm I did mine with a wooden clamp jig I made, and a ball pein hammer.
I pushed report the post instead of quote.Bradster68 wrote: ↑Thu Apr 04, 2024 3:07 amNo. Unfortunately I don't think we will be hearing from Stillerboy again. Last time we talked he told me he felt his time was better spent elsewhere. He helped me immensely and I'm sure many others. I personally will miss him.dukethebeagle120 wrote: ↑Thu Apr 04, 2024 2:36 amWhen you roll the lip your only taking the width of the flange.MooseMan wrote: ↑Wed Apr 03, 2024 9:51 pm I did mine with a wooden clamp jig I made, and a ball pein hammer.
What do I do.
Don't wanna cause any problems
Fixed.dukethebeagle120 wrote: ↑Thu Apr 04, 2024 3:28 am pushed report the post instead of quote.
What do I do.
- Twisted Brick
+1Bradster68 wrote: ↑Thu Apr 04, 2024 3:07 am
Yeah, Mars’s style has always been direct, mostly because of his passion for distilling and wanting others to do the same. Always willing to share his knowledge, but Mars is getting up there in age and has had to prioritize his time. It’s unfortunate to lose such a competent distiller, especially for the new folks here.
Mars is still around . He posted here a few days ago .
Well from emails we had back and forth that's what it appeared to me. Obviously I misunderstood what he was explaining. My mistake
Absolutely. A very dedicated man. And very generous alsoTwisted Brick wrote: ↑Thu Apr 04, 2024 5:44 am+1Bradster68 wrote: ↑Thu Apr 04, 2024 3:07 am
- higgins
Yummy, StillerBoy's last post was Mar 15 of 2023, not last month.Bradster68 wrote: ↑Thu Apr 04, 2024 6:11 amWell from emails we had back and forth that's what it appeared to me. Obviously I misunderstood what he was explaining. My mistake
Higgins
Flute build
Steamer build
4 methods experiment
Aging proof experiment
Next batch: Peated Bourbon (75% Corn, 25% peated malt)
Flute build
Steamer build
I don't know how to search a specific users post, or I would have before I commented.higgins wrote: ↑Thu Apr 04, 2024 6:50 amYummy, StillerBoy's last post was Mar 15 of 2023, not last month.Bradster68 wrote: ↑Thu Apr 04, 2024 6:11 amWell from emails we had back and forth that's what it appeared to me. Obviously I misunderstood what he was explaining. My mistake
He grew up in my neck of the woods.
It was nice to read him reminiscing about the old times
Clever... I'm gonna have to make one of thesedukethebeagle120 wrote: ↑Wed Apr 03, 2024 4:18 pm Make your own flange quickly
No welding
- Twisted Brick
If you have a member's screen name handy, just click on it. The member's post activity is listed mid-page on the right hand side.Bradster68 wrote: ↑Thu Apr 04, 2024 6:55 am
I don't know how to search a specific users post, or I would have before I commented.![]()
If you do not have a screen name handy, simply scroll down to the bottom right of any page and click on Members (next to Delete Cookies).
Click on Find a member and enter the Screen name, then Search. If you don't remember the screen name, go to your kitchen and fix yourself a drink (or refresh the one you're drinking). It then may come to you.
This really comes in handy when you want to retrieve a member's post you remember reading but can't remember the thread it was posted on.
Slainte!
Works a charm TB.Twisted Brick wrote: ↑Thu Apr 04, 2024 9:15 amIf you have a member's screen name handy, just click on it. The member's post activity is listed mid-page on the right hand side.Bradster68 wrote: ↑Thu Apr 04, 2024 6:55 am
Click on Find a member and enter the Screen name, then Search. If you don't remember the screen name, go to your kitchen and fix yourself a drink (or refresh the one you're drinking). It then may come to you.![]()
Slainte!
Hell yeah it does!Bradster68 wrote: ↑Thu Apr 04, 2024 9:26 amWorks a charm TB.Twisted Brick wrote: ↑Thu Apr 04, 2024 9:15 amIf you have a member's screen name handy, just click on it. The member's post activity is listed mid-page on the right hand side.Bradster68 wrote: ↑Thu Apr 04, 2024 6:55 am
Slainte!![]()
This bit I mean :-
Lmao. We all on same track.MooseMan wrote: ↑Thu Apr 04, 2024 12:58 pmHell yeah it does!Bradster68 wrote: ↑Thu Apr 04, 2024 9:26 amWorks a charm TB.Twisted Brick wrote: ↑Thu Apr 04, 2024 9:15 amIf you have a member's screen name handy, just click on it. The member's post activity is listed mid-page on the right hand side.Bradster68 wrote: ↑Thu Apr 04, 2024 6:55 am
Slainte!![]()
This bit I mean :-
Apologies to Duke for highjacking his thread a little.
This does seem like a great idea. And as someone who hasn't started his VM build,I will definitely be trying this method.
And if anyone is not that talented when it comes to soldering or welding, it's a fabulous alternative.
Hey no offense taken.
Just great conversation.
Have at it
Have at it
Doh , it was toohiggins wrote: ↑Thu Apr 04, 2024 6:50 amYummy, StillerBoy's last post was Mar 15 of 2023, not last month.Bradster68 wrote: ↑Thu Apr 04, 2024 6:11 amWell from emails we had back and forth that's what it appeared to me. Obviously I misunderstood what he was explaining. My mistake
Forgot to ask Duke, do you solder fill the back of the flange?
It doesn't show that in your photos.
When I rolled my flanges I filled the shoulder with a thick bead of solder and filed it to a similar angle as a Tri clamp flange.
One of them that had less solder fill, was an unreliable seal until I added more to thicken it up.
No.
Never had an issue
I do tighten the clamp down tight though
Usually they leak cause of not being level.
After rolling,a quick sanding to level out the mating surface takes care of that
Never had an issue
What are you using for gaskets?dukethebeagle120 wrote: ↑Fri Apr 05, 2024 9:37 am No.
Never had an issue
