as usual, i am taking enough for 3 x bottles off the first barrel (barrel 1) and topping everything along the way, finishing by topping up my large barrel with rum i have pre-oaked at 65%abv.
i live in a hot dry region, the barrels are kept in in room where the temp fluctuates quite a lot and we have just finished our hot seasons.
the original barrel strength was 65% but as usual the ABV has rose due to the angels share, which fortunately only seems to remove water content, which is predictable.
so the barrels range in strength at the moment
.........4/24......................6/22.......12/22....8/23 (ABV over the years)
barrel 1 72% (6L).................70%........68%......75%
barrel 2 77% (6L).................69%........62%(?)...67%
barrel 3 74% (6L).................66%........67%......68%
barrel 4 79% (15L)................67%.......68%.......69%
the question is....... when i refill barrel No1 from barrel No2, do i dilute the 77% from barrel 2 down to 65% before adding it to barrel 1?
and do i dilute the other as i refill the previous barrel in line.
maybe just dilute what i transfer to 65% to keep the ABV down a bit.
or just leave it?
i don't think the stock will increase in ABV as much over the colder months, but it will keep losing water in this region.
the amount of 65% pre-oaked rum i will add to barrel No4 will probably reduce the ABV to about 74%, but i'm not sure about adding 79% from barrel No4 to barrel No 3
it's a nice 'problem', the rum is luvly
