Electric heating wand for mashing.
If it plugs in, post it here.
This design of heater has been around for a long time. But seldom gets talked about around here.
All that's needed is an immersion heater and piece of oak to make a handle for it.
Pour boiling water over the grain, then use the wand to stir and add heat to the mash.
Pumping the electric wand up and down in the mash, while slowly moving horizontally works best. :wink:
Salt Must Flow
Re: Electric heating wand for mashing.
Post by Salt Must Flow »
You're not supposed to immerse that plastic part are you?
SW_Shiner
Post by SW_Shiner »
I had one that looked identical. Found out the hard way they are not water tight. If you had a way to make sure it is definitely sealed, and if it can handle the force.
Salt Must Flow wrote: Sat Aug 24, 2024 4:44 pm You're not supposed to immerse that plastic part are you?
Probably not, but the one I built lasted for several years before it got stepped on and bent.
I took the plastic piece off, insulated the wires and made a handle out of a wooded dowel.
