Paper Shredder Corn Grinder
I repurposed an old paper shredder to grind my corn. It does a fairly decent job. There's no adjustments for how fine it grinds but it's somewhere between cracked corn and course grits. It took a lil bit of troubleshooting to get it to feed correctly but I believe I have most of the kinks worked out of it. The only drawback is that it has an overheat circuit and the most you can grind at once is about 10 pounds before you have to let it cool down.
- NorthWoodsAb
Re: Paper Shredder Corn Grinder
That's not such a bad idea. Better than beating the life out of roller mill.
- Yonder
Great innovation Coonass.
Very innovative idea that, I like it!
I bet it's a noisy devil though, I've never used a quiet paper shredder.
It's a bit noisy but not terrible. I have a video of it running but it won't let me upload it on this site
Probably no louder than one of the cheap Chinese grain mills I guess
Sorry ,no video upload to forum . Have to post on you-tube and link .
BTW , cunning plan
Interesting, guess those shredders are tougher than I thought. I am always removing staples before shredding documents.
what does the corn look like after it's "shredded"? is it cracked or a finer grind?
- bilgriss
There's a lot of plastic in those shredders. Any mill or grinder I've used in the past with much plastic has had a short life. But it's definitely clever. I am also interested in the resulting grind appearance.
