Fermenting time
Lumbersnack
Fermenting time
Post by Lumbersnack »
Good morning,
I am fermentation my first sugar wash:
5 gallons of water
8 lbs of sugar (inverted)
6 oz tomato paste (nutrient)
1.25 tea of DADY
The temp has been pretty consistent around 85°F, hit day 27 yesterday, is that normal? It's that too long? How long should it typically take? Thank you for your help
pipes+hose
Re: Fermenting time
Post by pipes+hose »
Did you put yeast in?
Most ferments finish off in a week or two.
Check out bird watchers in the tried and true section.
viewtopic.php?t=5018
Re: Fermenting time
What makes you think that it isn’t finished?
JustinNZ
Re: Fermenting time
Post by JustinNZ »
Dude, it would be helpful if you included a hydrometer reading. If you have a bubbler that’s still bubbling occasionally that doesn’t mean it’s still fermenting. You could also taste some and describe that to the team. Always fun. Distance diagnosis is tricky without handy info! Good luck out there. But yeah, 27 days is a while for that kind of wash at that temperature.
I can’t sing, but I sing.
Twisted Brick
Re: Fermenting time
Post by Twisted Brick »
Take a gander at the sugar wash threads in the Tried and True section for fermentation times.
Shady's Sugar Shine
Prerequisite reading is listed in the blue boxes at the bottom of each page, including this one.
Salt Must Flow
Re: Fermenting time
Post by Salt Must Flow »
Is "tea of DADY" boiled yeast for nutrient? If so, boiled yeast amount appears correct. Your water to sugar ratio seems fine.
As asked previously, what's the Specific Gravity (hydrometer reading)? Did you pitch yeast? I see no mention of adjusting the starting PH and no mention of any source of Calcium Carbonate.
I'd check the PH. I assume you had a PH crash. If it's a PH crash, it would read 3 PH or so.
greggn
Re: Fermenting time
Post by greggn »
Salt Must Flow wrote: Thu Dec 19, 2024 11:55 am Is "tea of DADY" boiled yeast for nutrient?
I suspect "teaspoon" was what the OP intended.
________________
Re: Fermenting time
greggn wrote: Fri Dec 20, 2024 5:30 am
Thats how I read it too greggn.
Regarding fermentation time , I’ve had them still ticking over a month later . Unless I’m desperate , I just leave it to it .
Rusty Ole Bucket
Re: Fermenting time
Post by Rusty Ole Bucket »
I just finished 40 gallons of Shady's in 4 stripping batches. They all worked off in a week, then I let them sit a week before running. I adjusted the PH at the start of each and followed Shady's recipe to the letter.
Rusty
The Horny Goat Build
Electric Boozaloo II Build
