First time still set up and vinegar run
Bren_74
Post by Bren_74 »
I've just set up my 8.5gallon/37liter pot still with thumper. It's basically a vevor but with a different name on it.
Setting it up was easy and I got the vinegar wash up to 100c with no steam coming from anywhere it shouldn't.
I did try altering the temp a few times to slow down the liquid coming from the worm as if I were doing a spirit run. Im using a 2000watt induction plate, and although I dropped the temp to even 1000w at one stage the boiler temp remained at 100.
I didn't want to turn the heat off fully as I've read that if I do - and don't release the pressure - my boiler will implode!
Secondly, the liquid that i gathered over 40 mins running vinegar through, was totally clear with no oils or any other deposits in it - just nice clean clear liquid! I expected there to be some sort of dirt and/or oil in it. I did wash everything before assembling but am surprised that no detritus came out. Is it really worth doing a sacrificial run and wasting good money? I was thinking of just running clean water through for half hour to get rid of the vinegar and then calling it clean enough to start my first run!
Does anyone else use induction plates? And if so how do you control the heat? I gather my spirit runs should be carried out at around 80c? Do I just get to 80c and turn the heat off then back on again when the temp starts to drop?
Do I really need to waste time and money on a sacrificial run as there was seemingly no dirt come out in the vinegar run? Could I suppose that a factory made setup would have been cleaned before it left the factory? If so, why not just run a second vinegar run? What will running a sugar wash achieve that a vinegar run won't?
Any help appreciated.
Copperhead road
Re: First time still set up and vinegar run
Post by Copperhead road »
Bren, you will still need to do a sacrificial run, it’s not that costly just prepare a simple sugar wash.
Steve Broady
Post by Steve Broady »
Bren_74 wrote: ↑Wed Sep 10, 2025 7:47 am although I dropped the temp to even 1000w at one stage the boiler temp remained at 100.
You need to do some reading, I’m afraid. You cannot change the boiling point of a liquid by altering the power input.
It’s worth noting that you did not change the temperature to 1000w, you changed the power. The difference is not just semantic, it’s important that you understand what you’re doing as you control your still, and your use of the wrong term strongly suggests that you’re a bit unclear on the subject.
Changing the power input will change the rate at which you produce vapor, but it will not change the temperature of the vapor at all, and if there’s alcohol present it won’t change the proof significantly. Physics does that part, all you have to do is understand how different power inputs affect the product, and especially how it impacts the condenser and the way the still runs.
Bren_74
Post by Bren_74 »
Thanks for your replies.
Steve, I'm not trying to change the boiling point of anything but simply drop the temperature if the liquid in my vessel. If I put a pan of water on my stove and turn it up to 6 it will eventuality boil over. If I turn it down to 5 it will sit at a rolling boil. If I drop it to seeing 4 or lower it will stop boiling and cool down depending on whetted I've selected 1,2,3 or 4. That's all I wanted to do, cool the contents of my vessel down from 100c to 80c as I've read that 76- 80c is where I should be at for distilling ethanol. At least I believe that to be true.
I don't understand the power settings on my hot plate and so, I've got another hot plate coming tomorrow with temp settings on - probably won't be super accurate but I should simply be able to set the max temp of my liquid to 80c
If i was using gas all id have to do is turn the flame up or down (hotter or cooler) to adjust the temp and therfore the rate at which my still is operating/dripping which is all i want to do - i guess induction wasn't the way to go - but I don't fancy burning my house down and electric is often free unlike propane.
Steve Broady
I meant no insult, disrespect, or animosity, and I hope it was not taken as such. But I think you’ve missed something important. Take that pot of boiling water and measure the temperature. At a full rolling boil, it will be 100°C. If you turn the power down so that it’s just barely boiling it will still be 100°C. Water at sea level boils at 100°C. It’s either boiling or it’s not, but the temperature is always going to be 100°C as long as it’s boiling.
You cannot control a still by temperature. Read that sentence again until it makes sense. The temperature is ALWAYS dictated by the alcohol content in the boiler. No matter what clever technique you think you may have found, you cannot control a still by temperature. The only control you have is how much power you put in, which determines the amount of vapor you get out.
MooseMan
Post by MooseMan »
Bren it's good that you've done a vinegar run.
The sacrificial alcohol run you do next, will get rid of the things that the vinegar can't, you don't want stuff that's soluble in alcohol, in the first product you make do you?
Regarding the constant reference to temperatures, it's clear that you've not done quite enough research to fully understand how distillation actually works.
That's fine, while your basic sugar wash or whatever you make to do the sac run is fermenting, you'll have lots of time to do a bit more reading around here.
Lots of very useful links at the bottom of this page.
Bren_74
Post by Bren_74 »
I'm not quite sure where you're coming from. I think it's pretty clear that all I want to do is easily control the temperature of the contents of my still by adjusting the heat source in using.
I'm not into physics, but even i understand that if I turn the heat down under a pan, the contents of that pan will decrease in heat!
All I want to do, is control the temperature of the wash inside my still - turn up the heat, the internal temperature of the pot increases, turn down the heat, the internal temperature of the pot decreases. Allowing me to keep the temperature of my pot contents at the temperature I want - or indeed a temperature that creates the speed of distillation that I require. As I said, increase s propane flame and the pot contents will get hotter and the distill will flow faster. Turn down a propane flame and you will get the opposite. The problem I'm having is simply understanding how to undertake this very same thing with my induction hob which only has power settings.
NormandieStill
Post by NormandieStill »
Bren_74 wrote: ↑Wed Sep 10, 2025 9:54 am I'm not quite sure where you're coming from. I think it's pretty clear that all I want to do is easily control the temperature of the contents of my still by adjusting the heat source in using.
You're wrong. I'm sorry to be so blunt but you need to realise that this isn't a miscommunication but simply that you are convinced of a thing that isn't true.
Do you have a thermometer? (If not, how were you planning on measuring the temperature to see if you needed more or less power?)
Take a saucepan of tap water (cold) and put it on the hob. Now put the thermometer in and measure the temperature. Turn on the hob (low power) and watch the thermometer. If you want to do some real science, write it down every 30 seconds and plot it later. At some point it will reach 100C. Watch the boil. Turn the power up and watch the temperature and the boil.
You don't have to be a physicist to distill, but if you don't personally understand the physics then you might have to accept that there are people here that do and they are telling you that what you are trying to do is not possible. Ignorance of the laws of physics does not render them false I'm afraid. :wink:
higgins
Post by higgins »
Bren_74, read this link and it might help you understand what Steve, Mooseman, and Normandie are telling you.
https://www.kelleybarts.com/PhotoXfer/R ... gMyth.html
MooseMan
Post by MooseMan »
Thanks higgins I was trying to remember where to point the OP for some enlightenment!
SW_Shiner
Post by SW_Shiner »
Even if by some magic you were able to control a still by temp, a hot plate is the wrong heat source. Stills need a constant feed of power and a hot plate does not do that without modification.
Steve Broady
SW_Shiner wrote: ↑Wed Sep 10, 2025 1:18 pm Even if by some magic you were able to control a still by temp, a hot plate is the wrong heat source. Stills need a constant feed of power and a hot plate does not do that without modification.
That depends. I’ve seen some induction hot plates which are on constantly and have variable power. But for the most part, you’re right.
zach
Post by zach »
I used an induction hot plate successfully with a 5 gallon induction stockpot boiler for 6 years before I moved on to larger equipment.
The hot plate has variable power output with no modifications. In my opinion the hot plate is better set up than an internal element because I can run it with solids in the boiler with scorching. I've run with grape pomace making brandy and with wheat flour gravy making whisky.
The 5 gallon stockpot has a LM head, but I run it like a pot still when stripping. I can push almost full power (1800 watts). I run at constant power through the run and don't make any cuts and go deep into the tails.
For spirit runs, I run constant power at 1200 to 1400 watt with a 1 1/4" column packed with marbles for reflux. My take off rate is usually about 2 quarts an hour.
Temperature can not be used to control a pot still. The temperature of the boiler is useful so you know when to expect product out of the condenser.
30xs
Post by 30xs »
Where they are coming from is in order to get vapor from the still the contents must be boiling. You can control how fast it boils which will change how fast it produces vapors. Measure the temp of a simmering boil on a pot of water, also note how much steam (vapors) it’s producing. Now crank it up to full rolling boil and measure the temp, and vapor production. One of those things changed, but it’s not going to be the temperature. You can control the speed in which something boils, but no matter what speed it boils the temp will be the same.
