Hazy distillate early in the run
- PalCabral
Hiya distillers.
In my last stripping run, a Bourbon, I started getting a hazy distillate already when I was 25% through the run. Normally, haze shows up when I am reaching the end of the run, last 25%, but in this case it showed up at the 3rd liter of 11. I'll post a picture in a second. Is this something to worry about?
I have been using all self-ground cornmeal in this run, so it is different from other runs where I have used a mix of corns. Is this something one of you guys have experienced? Also, I imagine there's a slight blue tint in the haze too. Not sure. Could it be copper salts?
Will be running the spirit run next weekend but I'm not sure if I should keep this batch or not. Appreciate reassurances or stern warnings.
- PalCabral
Re: Hazy distillate early in the run
MooseMan
Seems way too early in the strip for it Pal, bit I would have said corn oils is the culprit.
Try chilling some, and see if it forms into sort of wispy clumps in the distillate.
- PalCabral
Thanks Moose. I'll try that. Cheers!
- PalCabral
There are clearly oil slicks forming on the surfaces, cream colored. Clumps I wouldn't call them, but little islands of oil slicks, some bigger and some smaller. Leaving it in the fridge a little longer.
Not sure if it’s visible on camera though.
- PalCabral
MooseMan
Hard to make it out from that pic but I know what you mean.
At the moment it's in solution as it's been emulsified by the hot alcohol but with time you'll likely start to see little wisps gathering as it drops out.
Ole Fogey
What colour was the wash? Could it be a puke? Kinda looks like a puke.
- BlackStrap
Was thinking puke as well...
Are you running a pot type still?
Found this interesting...
Louching is the primary cause of cloudiness when essential oils in your distillate separate from the solution upon dilution with water. This occurs because alcohol (ethanol) acts as a solvent, keeping oils in suspension. When you reduce the alcohol by volume (ABV) by adding water, the solvent capacity decreases, causing the oils to come out of solution and create a cloudy or hazy appearance.
Most questions can be answered here http://homedistiller.org/ and here http://homedistiller.org/forum/viewforum.php?f=46
Stay Safe & Have Fun
BlackStrap
BlackStrap
MooseMan
Yeah it does happen with dilution, and as I was saying, it will happen with time in a slightly different way, especially when cold, it will come out of solution by itself too.BlackStrap wrote: ↑Sun Mar 22, 2026 7:10 am Found this interesting...
- PalCabral
BlackStrap wrote: ↑Sun Mar 22, 2026 7:10 am Was thinking puke as well...
No puking or even foam ups today. This it is not.
Blackstrap, I just remembered that I was using nixtamalized corn in this batch. Not all of it but about 25% of the total amount of corn. Could this have something to do with it? The sample I took and cooled on Moose's suggestion still only have thin oil slicks on the surface and now the temp is down to 4C. The hint of blue is ever so fade, hardly detectable unless you're paranoid
- PalCabral
The ABV was between 30-40% abv when the louching started. Normally when this happens in a run for me, I'm down to 10% abv. And I wasn't cooling the condenser hard so the distillate off the spout would have been say 20-22C.MooseMan wrote: ↑Sun Mar 22, 2026 7:17 amYeah it does happen with dilution, and as I was saying, it will happen with time in a slightly different way, especially when cold, it will come out of solution by itself too.BlackStrap wrote: ↑Sun Mar 22, 2026 7:10 am Found this interesting...
Something simple like a small puked.
Since it's a stripping run, I wouldn't worry too much about it.
The change might be due to the recipe or a build up of oils in the vapor half of still from prior stripping runs.
- PalCabral
Today at the end of my spirit run, as I pumped up the power to collect feints, it happened again. Hazy distillate, which is to be expected as it was tails but still the ABV of what was coming out was 40% ABV, and an ever so slight blue tint to it. Didn't happen during heads, hearts or early tails, when I was running carefully, but when I pushed the watts up to +4kwh it came back. I decided to reduce the speed and the distillate started coming out less hazy and losing that blue tint.
I suspect it must come from the inside of the copper onion. After it happened in the stripping run above, I cleaned the inside of the onion with citric acid and then ran a steam run followed by a sacrificial. I have since ran two more stripping runs without any haze or blue'ish tints. The inside onion has "scars" running along the side following the vapor path. These are darkish - I'm not able to tell if they are black/grey or green. I'll see if I can post a picture, I know I took one.
Recap: running slow, no problem. Running 2kw, no problem. Running +4kw kind of blue (like Miles Davis would have said).
I'm not overly concerned but I would like to know if this is related to the marks I see inside the onion and if there is anyway I can fix them? For now I'll just use the onion for spirit runs where I will keep the speed low. For stripping runs I'll just run without it.
