Just finished my first UJSSM run, and was wondering......
La_Swampfox
.....if the collection rates, ABV's I obtained, and other things sound about right; or if I am pushing too fast/slow or doing something wrong? Actually, I have also completed the second run; and had intended to ask these questions after the first for your advice/comments; but didn't get around to it; and now will be running the 3rd generation in about 2 days as fermentation is basically stopped but will give 2 days to fully finish and settle.
The first generation run showed an ABV in my wash/beer of 9.4 with temperature corrected hydrometer readings. I put about 4.5 gallons in my 5 gallon still and kicked it off with my gas burner on high. I had decided to use my Thumper and had charged it with 2/3 wash and 1/3 of some 40% ABV Vodka the wife had here, about 30 ounces in all. At the 50 minute mark my boiler temperature was at 175 degrees F and my vapor temperature at the condenser inlet was a little over 100F and rising pretty quickly. Cut the fire down and turned the condenser water on. 5 minutes later I saw my first flow which was a sold pencil lead size stream, so cut the fire down a little more which got it to a very fast drip and occasionally a intermittent stream for a couple of seconds. My flow collection rate stayed the same throughout at 13+- minutes per jar (+- 1 minute as seconds were not figured in or calculated into it, just the current minutes shown on my watch) until the last 8 ounce jar which took 19 minutes. I checked the ABV of each jar as they were collected and full using a little refraction type meter that has shown itself to be fairly accurate as I didn't want to take the time or be fooling with my hydrometer on my first run. I collected and culled 8 ounces of foreshots, then collected 10 - 8 ounce jars that ran 65%. 60%, 54%, 52%, 50%, 46%, 44%, 41%, 38%, and 35% and cut my fire off and stopped collecting. All the jars came out crystal clear except the last one that looked clear by itself until held next to another, and then it appeared a little off or very slightly cloudy. I gave numbers 3-7 a quick diluted taste test and deemed #3 was probably mostly heads and #7 was probably mostly tails, and #4 - #6 were probably mostly hearts after airing them for 48 hours. They smelled good and tasted OK; like alcohol, not really good as I am used to a finished Bourbon, but not bad; and surely drinkable as is; .....but hopefully a lot better when sour mashed and aged some. LOL
The 2nd generation run was pretty much the same. Forgot to check and calculate the FG and ABV of my wash; but should have been close to the same I would guess. Ran the same approximate 4.5 gallons of the sour mash wash and charged the Thumper this time using 2/3 of the 2nd generation sour mash wash and 1/3 of my 1st generation collection using about half of my #3 jar/last heads, and about half of my #7/first tails jar; and poured the remainder of those 2 jars into my boiler with the 2nd generation wash. Everything time wise ran nearly exactly the same. Only difference was I ended up collecting 13 - 8 ounce jars instead of 10; which I guess should be expected as I added 16 ounces or a little more of fairly high proof alcohol into the run. The ABV of the jars collected using the same refractometer was 67%, 63%, 60%, 59%, 55%, 53%,50%, 48%, 44%, 43%, 39%, 37%, and 34% when I cut the fire and stopped collection. Just out of curiosity I checked the ABV of the foreshots and got an ABV of 70%. Collection time again ran at 13+- minutes per jar until I got to #12 which took 15 minutes and #13 which took 16. Again after airing for 48 hours all were crystal clear and smelled good. I did notice that again #12 ans #13 looked clear until held up against one of the others, and then appeared slightly cloudy. There also appeared to be a very slight oil sheen that floated to the top of both while airing that was barely perceptible, but it was there. is that normal or a problem I caused? Only tasted a couple jars that I deemed to probably be "numerically" or "statistically" hearts. and they again tasted like clean alcohol and were OK and drinkable.
Do the volumes collected and the ABV's for each jar in a run starting with a (9.0-9.5% wash sound about right to be collecting in a pot still with a Thumper in use? Does the run collection rate/time per jar sound about right, or it too fast or slow? Will greatly appreciate any advice or comments!!
- PalCabral
Re: Just finished my first UJSSM run, and was wondering......
What kind of still are you using, Swampfox, is it a reflux column or are you running one and dones on a pot still?
It’s pretty difficult to make a judgement on your flow when you are talking jars. Could you recalculate it to ml per minute (or oz per minute), then it’s easier to compare. Typically you talk of LPH (liters per hour) when it comes to producing product. When I get to my computer I can share how I document the run, maybe it helps.
La_Swampfox
PalCabral:
Sorry about that; think I mentioned they were 8 ounce or half-pint jars; ....and IF my old memory serves me correctl, they are just under 30ml per ounce; but as the jars were probably a tad over the 8 ounce/full mark, I'll say they contained 240-250ml each; ....so that should be somewhere around 18.4 to 19.0ml per minute; .....or about 0.62 oz./minute.
It is a straight pot still with thumper, no column. but does have a small expansion chamber I added directly to the top of the boiler to hold a couple pure copper scrubbers due to it being all stainless steel construction. I have pictures of it in a post from a little earlier when I got all the modifications made, along with my Liebig condenser, and got rid of all the questionable Chinese brass fittings and replaced them with stainless that you can check out for a clearer understanding.
- Copperhead road
I am a mls per minute Man, i find it to be the easiest way to make sure you are not running to fast.
There can be great differences running a toothpick stream, and you can be running way to fast.
- PalCabral
No worries, Swampfox, and thanks for sharing the ml/min, makes it a lot easier to get a picture of the speed you're running at.La_Swampfox wrote: ↑Sun Sep 13, 2026 9:32 pm PalCabral:
Thumper or not, I think you're not making it easy on yourself running one and dones. I've never ran UJSSM but I can't see why it would be any different from any other wash. I always double distill, which makes the second run much easier from several perspectives, including how fast you can run.
The speed of how you run your spirit run it is relative how much is in your pot and what is in your pot. The smaller volume, the slower you need to run, vice versa with a bigger charge. The lower the ABV in your pot, the slower you run, vice versa with a higher proof. I don't have any experience from operating a still with a thumper, so I'm unsure if that changes much.
I have only once run a one and done and for that run my average run rate was 14.1ml per minute. It was a 6g charge @8.6% ABV. Even though I snailed through it for a total of 8 hours back to back, it smeared a lot and it's the one alcohol I've made I hardly ever touch.
In one of the active threads there's a discussion about how fast you run your spirit run, check for "Running too slow". A common view is that the spirit run takes about 6 hours from first drop until you're done with tails (going into collecting feints, if you do), regardless of how big your charge is. Basically, if you're running a 8g still or a 26g still, you'll be adjusting your flow accordingly and arrive at the same run time. Magic, isn't it
But the caveat is that I believe everyone is talking doubling runs, not one and dones. Well, Copper can tell me if his one and dones on the plated column is faster or also 6 hours.
I document my spirit runs (stripping runs just goes into one big bottle/bucket) in Excel and for each jar I document volume collected, ABV, timestamp, flow rate (as in cl/minute), and a recalc of that in LPH. It makes it easier to trouble shoot and to follow what you did during the run. I believe many guys here document more or less in a similar way, at least as long as we are building up experience. I doubt the more experienced guys bother.
- Username
This may appear slightly off topic but I don't think it is.
I also have never used a thumper, but started with a plated column, both of which I believe as sold as "one and done" still's
You will make life so much easier if You do a bunch of stripping runs 3-4, whatever volume fits your boiler nicely.
The volume of final spirit is greater and easier to make good cuts on. Yes you will have say 3 stripping runs and a spirit run, 4 in total as opposed to 3 but your time investment will be smaller. Stripping runs normally take me 2 hours (less for a second if I'm pre-heating) so thats 6 hours and a 6 hour spirit run, 12 hours in total v's 3 x 6 hour spirit runs for 18 hrs
When I started out I was doing one and done runs but have almost exclusively changed to stripping runs followed by spirit run
- higgins
The first thing I noticed was that you are only collecting 10 or 12 jars, 8 oz each. I would double that ... 24 jars at 4 oz each. This will reduce smearing and make cuts easier. 24 jars at 1 jar per 15 min = a 6 hour run, about 0.5 LPH. (In reality, I'd collect the first 4 or 5 jars at about 30 min each, then speed up to about 12 min each. It will naturally slow down as you get into tails.)
In my opinion double distilling (stripping runs followed by a single spirit run) gives you a cleaner spirit that can be imbibed right away.
1x* or 1.5x** runs give you a rougher but more flavorful spirit that needs to be aged 3+ years to get really good.
* 1x is one and done without a thumper;
** 1.5x is one and done using a charged thumper, or a spirit run using a mix of beer & low wines
I had a quick glance through this thread earlier on today and the numbers and info were not adding up for me.
I think you are spot on with what you are saying higgins.
La_Swampfox
Thanks to all for the previous replies, info, and opinions. Guess I should have explained why I chose the thumper method. I have always heard and read from many sources and forum posts that a pot still with a thumper produced the most flavorful whiskey; which is what I am looking for, not highest proof or the most volume I can obtain. And even when the commercial Bourbon distillers started to transition to column reflux stills many years ago, they found they had to use a doubler, or thumper of sorts, to keep the taste of their former pot still products. I had intended to keep the 1st generation "sweet run" and my 2nd generation "sour mash" run separate to play with by blending and aging to see what it produced flavor wise with the "1.5 run and done" old school method; and to have it to compare to my later generations that I intended to strip run, combine, and then a spirit run as most of the forum members seem to do and advise. It was just a way for me to compare and see, or rather taste, the difference in the 2 methods. I figured my first attempts while learning and working with a sugar wash like UJSSM was the place to experiment and learn, not later when maybe graduating to an all grain.
I gather from the comments, although it wasn't definitively stated, that I was running too fast and need to slow my flow; even though I was getting about 3 or 4 to maybe 5 drips a second; with an occasional tiny broken stream for a second or two at most. No one specifically commented on the very slight cloudiness of my last collection jars in the 37%-35% range, or the barely perceptible oil sheen on jars #12 & #13 on my 2nd run. I guess that was some of the fusel oils I have read about, but is this normal when getting into the tails, or because I was pushing it too hard? I also have seen several posts on here from moderators and seasoned senior/veteran members advising beginners to not go below 20% on their first runs when learning, and some even saying to stop at 40% when doing your very first runs. I decided to cut it off when I reached 35% or below on my last full collection jar. I was also reaching a temp of 204+F at my condenser inlet at this time on both runs which I took as another good signal it was time to stop. The recommendation to use 4 ounce jars for collection has really thrown me a curve ball; especially since I don't have any that size, never saw any that size, ....and it would take a bunch of them. Have a good many 8 ounce and 16 ounce jars on hand from many years of home canning; ......so guess I could just fill them half way??
Saltbush Bill: Wish you had elaborated more on your comment "the numbers didn't make sense"; as that gives me no indication of WHY they don't?? Is the volume collected off from your expected with a 35% cut-off? The ABV's per jar collected off from what you would expect with a pot still and thumper with a 9%+- sugar wash?? The collection rate/time per jar?? Or is/was it something else??
As I said it was a quick skim,
It was more a reference to using more cuts jars to make that side of things easier for your self.
More jars with less in them helps when you are learning.
Also Ive found that when your getting used to the different smells it helps to start with the middle jar, then jump 3 jars to one side. Then another 3 jars along.
That makes the difference in the smells much more noticeable.
Play around like that for a while and you start to get the hang of it.
You dont need to use 4oz jars, just more jars with less in them.
- Copperhead road
Its funny i learnt that way and still now ten years later i still collect in 300ml increments if i am running my potstill. running a plated bubbler i collect in bigger jars.Saltbush Bill wrote: ↑Mon Sep 14, 2026 6:16 pm As I said it was a quick skim,
- PalCabral
I think the use of a doubler in the Bourbon industry should be regarded as a second distillation rather than a thunper/retort. Although the flow from the beer still to the doubler is automated, the doubler performs a distillation of its's own accord, It's a common misunderstanding thinking the doubler is a retort/thumper, slaving under the steam from previous boiler's.La_Swampfox wrote: ↑Mon Sep 14, 2026 2:59 pm I have always heard and read from many sources and forum posts that a pot still with a thumper produced the most flavorful whiskey; which is what I am looking for, not highest proof or the most volume I can obtain. And even when the commercial Bourbon distillers started to transition to column reflux stills many years ago, they found they had to use a doubler, or thumper of sorts, to keep the taste of their former pot still products.
Again, speaking of drips and jars is not particularly helpful. Use the ml or oz at the spout so it's possible to compare with something. I use 5 different sizes of jars in my second run, and I collect at 250ml, 300ml, 500ml, 1L, and 2-4L depending on where I am in the spirit run. Jars are collection vessels. I use one collection vessel for my stripping run, but I am still checking the flow and the ABV for every liter or so I produce.La_Swampfox wrote: ↑Mon Sep 14, 2026 2:59 pm I gather from the comments, although it wasn't definitively stated, that I was running too fast and need to slow my flow; even though I was getting about 3 or 4 to maybe 5 drips a second; with an occasional tiny broken stream for a second or two at most. No one specifically commented on the very slight cloudiness of my last collection jars in the 37%-35% range, or the barely perceptible oil sheen on jars #12 & #13 on my 2nd run. I guess that was some of the fusel oils I have read about, but is this normal when getting into the tails, or because I was pushing it too hard?
There is a difference between one and dones and doing stripping runs. In a stripping run, I often get cloudy distillate when I am getting down to 20% ABV. Although there are no cuts made in a stripping run, theoretically I would be in the "tails" at that point, running as hard as I can. The cloudiness is probably a combination of "tails" components and the speed I am running at, it never bothered me as I will distill all the low wines a second time. I never get cloudiness in a spirit run.La_Swampfox wrote: ↑Mon Sep 14, 2026 2:59 pm I also have seen several posts on here from moderators and seasoned senior/veteran members advising beginners to not go below 20% on their first runs when learning, and some even saying to stop at 40% when doing your very first runs. I decided to cut it off when I reached 35% or below on my last full collection jar. I was also reaching a temp of 204+F at my condenser inlet at this time on both runs which I took as another good signal it was time to stop.
As for when to stop collecting, there's no rule. Both collection of distillate coming from your still and the cuts you make from that collection are the distiller's choice and based on your smell and taste senses. This is why I was asking about how you experience the flavors from your distillate. We are not distilling in one way or the other because we want "the most flavorful whiskey", we are distilling because we want the best flavors from the mash. The flavors in spirits primarily sit in the heads and the tails, generally in the borderlands between heads-to-hearts and hearts-to-tails. Having a run when heads, hearts, tails are smeared means that yes, we get lots of flavors but we can't separate them efficiently.
In a spirit run, where I am distilling low wines for a second time, I usually stop collecting in jars between 50% ABV and 40% ABV off spout, meaning that I don't consider any subsequent distillate coming out of the still ever going to be part of my hearts. When I make the cuts from all the jars I have collected, I rarely add any jar below 50% ABV in my hearts cut, usually the lowest ABV I keep for oaking with sticks on glass is 60%-58% ABV.
The cuts I make are based on my taste. Sometimes, I go "deep in the tails" because there were interesting flavors there. Other times, the tails are quickly just bitter and bad. The cut off point will differ between run.
I think Salty's answer is spot on.La_Swampfox wrote: ↑Mon Sep 14, 2026 2:59 pm The recommendation to use 4 ounce jars for collection has really thrown me a curve ball; especially since I don't have any that size, never saw any that size, ....and it would take a bunch of them. Have a good many 8 ounce and 16 ounce jars on hand from many years of home canning; ......so guess I could just fill them half way??
La_Swampfox
Sorry for being late in getting back to this post, and again; .....many thanks to all who have replied with helpful suggestions and information. Hope you all didn't think I had abandoned you or was ignoring you. Had to make an unexpected trip out of town, and when I was home I've been busier than a one armed paper hanger in a wind storm trying to catch up and get all that needs doing done. Since my last post/reply I did do the 3rd generation UJJSM run and cut the speed way down as all suggested. I thought the faster original speed had tasted OK, but only like a neutral spirit/alcohol taste with very little corn flavor that I was expecting or many had described as "in your face corn". LOL The slower speed definitely made it a cleaner taste, but I then decided even though they were all 1.5 distillation runs, I would throw them back into the boiler/kettle and run a true Spirit Run with the thumper which should be close to 3 distillation runs of my product. First I must give credit and props to a couple of you veteran distillers......
PalCabral & Higgins both posted earlier that "your Spirit Run should take about 6 hours, regardless of the size of your still or charge". To be honest, I had serious doubts about that, as it goes against common sense ; but UNBELIEVABLY, on my very first Spirit Run from my first drop of distillate to cutting off the fire and catching the last drop was EXACTLY 6 HOURS TO THE MINUTE!!! PalCabral said ..."it was magic";..... and it appears it really is!! LOL
The next big surprise I got was the the steady concentration/ABV of my Spirit Run collection. My first 3 semi-slow "1.5" Runs went as I expected, with the first jar coming out highest at around 65%-67% ABV, and each jar thereafter dropping off 2%-5% in a steady decline until I stopped at 35%. When I ran my Spirit Run I used all of the 2nd and 3rd generation distillate, plus all of the 1st generation "sweet" distillate except about 16 ounces of the "Center Hearts" I kept separate to play with. This time it took some playing and careful adjustment during Foreshot collection and my first jar of Heads. I got lucky I guess, and got my fire tuned just right and went through collecting 80 ounces over a 4 hour and 5 minute period at a 11.5ml/minute average rate with the temperature staying at 178 degrees F until the last 42 minutes went it went up to 179 degrees F. I COULD NOT BELIEVE that over this 4 hour period the ABV and temperature nearly stayed the same; only running from 73% to 71%; going both up and down, with the overall average at 72.3% and 1 degree of temperature change!! And never had to touch or adjust the fire! The next 16 ounces were at 69%, then 8 ounces at 66%, 8 ounces at 60%, and finally 8 at 40% when I cut the fire as the last 2 jars collected had increased by 10 and 15 minutes in time respectively, even after bumping my fire up just a tiny bit; and my vapor temperature at my condenser inlet was rising fast and had jumped from 188F to 206 degrees F at cut-off on the last 2 collections, with a tiny oil sheen showing up on the very last jar.
My Spirit Run was small (only 235 ounces total with the dilution water included) from the 3 previous Stripping Runs minus part of the Hearts from the first. When diluting, I did not correct for temperature in the calculation, so when checked it actually came out to 38% ABV instead of 40% that I was running in my Spirit Run .....which works out to 89.3 ounces of alcohol available. I ended up collecting 120 ounces total at 68.4% ABV (including that last jar at 40%) so ended up with 82.1 ounces of alcohol; or recovered 92% of what was available. All but that last jar look and smell amazing; and needless to say I am happy with the results from my first complete distillation runs. Can't wait to find the time to start tasting and separating and get some of this on a charred White Oak spiral to oak, mellow, and age a bit. Currently have my idea for a "bastardized/cross-breed" fermenting; .....my current UJSSM on its now 4th generation ferment with a couple pounds of steeped corn that were added to replace the spent corn; plus some malted 6 row barley and some malted soft red winter wheat. The aroma being released in the escaping CO2 is AMAZING; and I think I could drink it as it is ; ....if it tastes as good as it smells. LOL
- PalCabral
Congratulations, Swampfox. I am very happy for you. Sounds like you are well on the way now to start getting consistently good results from your runs. From now on, you're just going to improve your process.
If you're running slow through your hearts in a pot still doubling run, having the ABV just sit at a specific number for a long time is very common. You're basically just extracting the ethanol from your boiler in an even flow. This is often followed by a quite fast and sometimes very dramatic fall of ABV. Over just a few jars you're suddenly in the low 60'ies.
One thing that struck me a bit curious with your description was that your ABV was going up and down between 72-73%. When you find a flow like you describe, you'll usually just at one ABV and then slowly go down, until it falls hard. I wonder what the fluctuations comes from. It's an indication that you might still be smearing more than you need to, although fluctuations between 1% ABV is really small. Are you running on a hot plate or is your still sitting somewhere where it can get impacted by airflow?
La_Swampfox
Good Morning PalCabral:
Seems once again you may have presented an answer to a question I had in my mind, but wasn't too really concerned about as my spot checking the ABV while collecting during my run was more of a FYI or curiosity; .....and whatever is collected "is what it is". I was only using a very inexpensive refractometer for the speed and simplicity of not having to fill a test jar and taking hydrometer readings while other things are going on; but that surprisingly has shown itself to be pretty darn accurate when tested against known ABV's of different spirits. I naturally use my hydrometer for my OG and FG readings when doing my fermentations, and I will definitely be using it when making my barrel/aging proof and final proofing calculations for a more accurate assessment.
I had attributed the "up & down" variance to possibly a couple things, ......or maybe to both. That is an inexpensive refractometer that I have no idea what the supposed accuracy or repeatability is; and my old 75+ year old eyes coupled with a very fine and tiny scale bar that is sometimes hard to read when up in the higher ABV ranges, as the scale bar graduations get even tighter and smaller as you go up the ABV scale bar shown. As I said, I was shocked to see the ABV stay within 1% either up or down for that long, and did not know that was common or to be expected. In actuality, looking back more closely the first part of that 4 hour period it was between 73& and 72% the majority of the time and between 72% and 71% the rest with an occasional blip in that pattern of a steady/slow decline. Your second guess is what I had not even thought of considering. I am running in our kitchen on a natural gas stove, and there is indeed an air conditioning vent overhead in the ceiling that is only 5 feet away from my boiler with the fixed register louvers pointing directly down to where the boiler sits on the stove. It was in the middle to upper 90 degrees F when I was making my run and the A/C was cycling on and off. BINGO!! I think you nailed the cause!! I have thought about making a simple insulation jacket for the boiler out of some of that lightweight foil covered bubble type insulation, but was only thinking of getting my temperature up quicker to shorten my total run time, and was not considering keeping my temperature more consistent when reaching distillation temperatures.PalCabral wrote: ↑Tue Sep 22, 2026 9:52 pm
La_Swampfox
Forgot to mention.......
This was indeed another surprise and shock; after seeing 72%+- ABV for so long, then a small of amount at 69%, then even a little less at 66% and a good solid 60%; .....that the next jar fell a full 20% to 40% ABV. Makes life simple as there is no second guessing yourself whether or not you have reached the stopping point. LOLPalCabral wrote: ↑Tue Sep 22, 2026 9:52 pm
