Should I strain a corn mash?
ginzo
Post by ginzo »
Should I strain a corn mash or should I put everything into the boiler? I have a SS still with the element inside the boiler. I have heard that those will get mash burned onto them. What is best?
Grayson_Stewart
Post by Grayson_Stewart »
You will have to strain it when using internal elements or have a burned taste come across.
Yttrium
Post by Yttrium »
Unless you have an external heat source and a double boiler, you'll want to strain the grains out. In my limited experience, double boilers are usually more trouble than they are worth.
The future is not set. There is no fate but what we make for ourselves. --John Conner
Uncle Remus
Post by Uncle Remus »
Yes strain off the wort (liquid) . The last batch we did, we strained it and put it in a couple of carboys and then let it settle and syphoned it off a couple of times. The wash we threw in the boiler looked nearly as clear as a white wine. We do the same with sugar washes too. IMHO the clearer your wash is, the better your end product will be.
Give a man a fish and he will eat for a day. Teach a man to fish and he will sit in a boat all day and drink beer.
Grayson_Stewart
Yttrium,
I just picked up a 40 gallon hot water heater to use as a double boiler so I can do some fruit washes on the pulp. What problems have you experienced with a double boiler?
Guest
Post by Guest »
May i ask, if you strain your washes then why do people continue with those crazy upside down bowls when you can just weld on a threaded coupling.
just askin
Uncle Remus
Anonymous wrote:May i ask, if you strain your washes then why do people continue with those crazy upside down bowls when you can just weld on a threaded coupling.
just askin
We also use the keg to cook mash. Makes for easier cleanup with a big hole on top of the keg.
Yttrium
Post by Yttrium »
One problem with a double boiler is the extra heating losses. You just end up wasting a lot of power. Increased energy losses result in longer run times. Secondly, with a double boiler, you loose some control over the heating of a wash. You simply can't respond as fast to change the amount of power being input into the wash.
Grayson_Stewart
Yttrium wrote: Increased energy losses result in longer run times. Secondly, with a double boiler, you loose some control over the heating of a wash. You simply can't respond as fast to change the amount of power being input into the wash.
I run two internal elements now. Both for boil up and one for the main run. If I insulate the double boiler it seems to me it would operate about the same, just ake a little longer to reach boilup due to the extra liquid surrounding the main boiler.
Also, I have no potentiometer on my elements now so I have no control. I think a small loss in efficiency might work out just right for grains and fruit pulps since my smaller element is 1800 W.
Granted it's not perfect...thanks for the input Yttrium.
