6" type L copper ponu still build
Post your builds here.
rednose
Re: 6" type L copper ponu still build
Post by rednose »
What I don't get is the "blue tube tied on the black line" :?
ozone39 wrote:I'll throw the schematic on this post. It's floating around somewhere else on HDO I had posted it earlier, but it's probably easier to see and understand with the pictures...
ozone39
Post by ozone39 »
The blue tube is "expanded" for clarity. The condensed alcohol drops down this tube (blue tube) into the lower coil where it is flashed off again by the steam heated coil. Alcohol rises back up and goes out the vapor receiver tube that goes to the condenser. I have found that by sizing the lower coil to the drop tube creates a mini "thumper" reaction with the falling condensate running into the rising vapor.
rednose
Post by rednose »
Thanks for the explanation ozone, I think I got it now.
I like the compact size of your still.
ozone39
Post by ozone39 »
Well, I'm absolutely completely impressed with the results. Grabbed 10L of cheap wine (%12 ABV) at the store, added another 5L of water and ran her. Once the gauge hit 185 she was at %93, leveled off at %80 stopped putting out at %75. Had to crank the burner up and start forcing out product (not a standard practice by any means) and she hit %70 and just quit....Think I got a winner here....Be running the wash through her next week... :mrgreen:
finished ponu.JPG (20.15 KiB) Viewed 3616 times
ponu still complete 2.JPG (18.05 KiB) Viewed 3617 times
ct1870
Post by ct1870 »
That is one hell of a still head. Beautiful work, compact and good %gs on the output. How much could I get one for? 12% to 80% constant heart I am assuming did it help make it easier to separate the heads hearts and tails and how is the flavor?
ozone39
Post by ozone39 »
Carries a lot of the grain flavor with it (I run with a half barley and half rye wash). I am currently working on installing a temp gauge in on the condenser side. She is a very sensitive to how much cooling water is applied to the condenser side. My first run with a batch of wash was like watching the movie shakes the clown, (difficult, but funny). But the learning curve is starting to level out and the product is getting much better...
ozone39
Post by ozone39 »
She's to sensitive...Pain in the ass...I'm gutting her out and going back to the drawing board...Air cooled primary condensate tube is essential.... :esurprised:
Cartierusm
Post by Cartierusm »
Ozone, what are you saying that you're not going to use this still at all and make a new one? That sucks, kind of. I only say kind of becasue although I love distilling I also love build the dam things too. Well good luck on the next one.
Samohon
Post by Samohon »
Make me want to take a coarse on oxy/acetalene brazing tecniques.
Looks great man.. Thanks...
S.
♦♦ Samohon ♦♦
ozone39
Post by ozone39 »
She's getting gutted out tomorrow night. Gotta a new plan drawn up that is so far out of the box I can quit thinking about it. Air cooled primary vapor tube here we go......Were going to have some MAJOR surface area on this one....
olddog
Post by olddog »
I love seeing still developement and builds which think outside of the square, I look forward to see your new developement. :D :D
OD
ozone39
Post by ozone39 »
The rebuild/redesign has begun....
ponu rebuild 2.JPG (18.94 KiB) Viewed 3032 times
ponu rebuild 1.JPG (19.76 KiB) Viewed 3033 times
Man I love your work Ozone. You got some skills.
Just wish I knew what I was looking at. :oops:
blanikdog
Post by blanikdog »
Me too, larry. :oops: :) :)
blanik
Cumudgeon and loving it.
ozone39
Post by ozone39 »
more progress made today. Try and get it all sweated up later this week...Summer's here so progress is slow..
sectioning plates
sectioning plates
condensers seem to always be a pain in the ass to fit up and sweat...
Samohon
Post by Samohon »
This is great ozone. Still, no pun intended, trying to work it all out.
Good luck with this build and Keep it goin man....
♦♦ Samohon ♦♦
hstuurman
Post by hstuurman »
He Ozone,
Very nice build, but.... What are you building?
Can you explain how this one is ganna work?
Henk
Henk
ozone39
Post by ozone39 »
It's still a ponu. I'm just utilizing 4 ea .375" diameter tubes as my primary vapor tube instead of one 3/4". The initial vapor travels up these tubes and back down through the condenser, condenses back to liquid and then will hit the lower coil (not installed yet) and flash off into the secondary coil (this one is installed) and come out as product. I went with 4 ea 3/8" tube to keep it uniform and I would have had to offset the tower to one side to fit a 3/4" piece of pipe..4-3/8" tubes have the exact same surface area as one 3/4" (2.355 sq inches). Thanks again for the compliments, I'm going to try and get her sweated up by weeks end. But with summer here kinda makes it tough..
hstuurman
Post by hstuurman »
OK, Till now I understand,
Steamchamber, primairy steamtubes (4, looking great! :D ) going on top into the condenser, into lower coil. Output throug cooiling coil.
Still the same as the ponu, but what are these big holes?
And when you build the inside (4 tubes connected to the lower coil) pleas send pics!! :ebiggrin:
Henk
Henk
ozone39
Post by ozone39 »
Holes are access ports so I can get my torch in there to sweat up all the joints. I guess they will add some ascetics to the still as well.....
Kentucky shinner
Post by Kentucky shinner »
That is one cool looking still dude. I cant wait to see the finished product and hear how she runs.
KS
ozone39
Post by ozone39 »
Well, wife is out of town, kids are with the cousins, it's rainy and shitty out, beers are cold and the tunes are loud... These are the elements for progress....Things left to do: install cooling line ports, secondary vapor tube, install parrot.....Getting close..
olddog
Post by olddog »
I Like it :D :D :D :D
OD
hstuurman
Post by hstuurman »
Damn man, this is (again) turning to be a beautiful, extraordinary build.
Those 4 steamtubes look great :D , how are you gonna finish these acces holes?
Henk
Henk
ozone39
Post by ozone39 »
Think I'm going to leave them as they stand....
I think I'm getting it.
Just wish I could see a flow diagram.
Really nice work.
olddog
Post by olddog »
Looks like another nomination for the stillbuilders hall of fame. :D :D :D
Great work Ozone
OD
blanikdog
Post by blanikdog »
You blokes are bloody incredible.
blanik
olddog wrote:Looks like another nomination for the stillbuilders hall of fame.
Great work Ozone
Indeed.
And please pass the gray poupone :wink:
ozone39
Post by ozone39 »
Thanks for the comments guys, I appreciate it..With the old lady out of town things get done..Made some more progress tonight. Really all that's left is attaching the parrot and installing the primer/flushing valve (and distilling of course). After that sanding off the access solder and shooting it in the walnut blaster will be on call...
ponu still comp.JPG (15.5 KiB) Viewed 2943 times
ponu water outlet.JPG (14.64 KiB) Viewed 2944 times
making sure nothing leaks
ponu water test 2.JPG (10.83 KiB) Viewed 2943 times
ponu still complete 1.JPG (18.2 KiB) Viewed 2943 times
