Thanks for the warm welcome!
Bull Rider wrote:Greetings Acrolein:
Interesting handle.
Acrolein (systematic name: propenal) is the simplest unsaturated aldehyde. It is produced widely but is most often immediately reacted with other products due to its instability and toxicity. It has a piercing, disagreeable, acrid smell similar to that of burning fat.
Burning Fat! Yikes...
Bull.
I couldn't think of anything so I picked a random whisky flavor ingredient
. Although when you describe it that way it sounds even less desirable!
WalkingWolf wrote:down at the bottom of this
thread you will find Harry's explanation on how he makes his peat reek.
Thanks, that's very helpful. I can't smoke the grain as I've no suitable smoker and I'm not handy enough to build one so getting the right peat flavor has been tricky. I may give this a shot. I've been smoking my oak chips over a peat fire but that doesn't give as much flavor as I need.
LWTCS wrote:Welcome and good luck.
How big is your boiler?
Microscopic, 6 liters. I'm on my fourth run now, I do a 3 gallon/7 pound two-row infusion mash, so about a 1.7 ratio for OG 1.070~/FG 1.016~, using a Champagne yeast (I intend to use a more authentic to style yeast later). Supposedly I want a thin mash for whisky making but that's as thin as I can bring myself to go at the moment as it takes me three stripping runs to get through one batch. The real distilleries do a 3 step infusion at varying temps but I've eschewed that approach in favor of fermenting on the grain to maximize yield and flavor then making a thin mash out of the spent grain for the next batch. I've read this was the pre-modern approach but I could be wrong.
My current problems are yield and flavor. For the first three batches I was flying blind with no hydrometer so I might have screwed up fermentation but the spirit runs yielded a pathetic 10-12 oz., absurdly low by all my calculations. The current batch's gravity is correct so I'll see if that was my past problem.
As for flavor, my first batch was fantastic; lots of warm grain taste straight out of the still, deliciously oily and rich. The next two batches have the same issue, an extremely hot and light taste before it gets into the regular whisky taste of ethanol/esters/oak. I'd assumed it was methanol/acetone and that I needed to be more ruthless with foreshots so I threw the whisky on the stove and heated it to 65C for five minutes. No luck. They've been aging for a month now on toasted/charred oak and the problem hasn't resolved.
