I really appreciative it.
Vapour Flow Conditions
Adverse vapour flow conditions can cause
Foaming
Foaming refers to the expansion of liquid due to passage of vapour or gas. Although it provides high interfacial liquid-vapour contact, excessive foaming often leads to liquid buildup on trays. In some cases, foaming may be so bad that the foam mixes with liquid on the tray above. Whether foaming will occur depends primarily on physical properties of the liquid mixtures, but is sometimes due to tray designs and condition. Whatever the cause, separation efficiency is always reduced.
Entrainment
Entrainment refers to the liquid carried by vapour up to the tray above and is again caused by high vapour flow rates. It is detrimental because tray efficiency is reduced: lower volatile material is carried to a plate holding liquid of higher volatility. It could also contaminate high purity distillate. Excessive entrainment can lead to flooding.
Weeping/Dumping
This phenomenon is caused by low vapour flow. The pressure exerted by the vapour is insufficient to hold up the liquid on the tray. Therefore, liquid starts to leak through perforations. Excessive weeping will lead to dumping. That is the liquid on all trays will crash (dump) through to the base of the column (via a domino effect) and the column will have to be re-started. Weeping is indicated by a sharp pressure drop in the column and reduced separation efficiency.
Flooding
Flooding is brought about by excessive vapour flow, causing liquid to be entrained in the vapour up the column. The increased pressure from excessive vapour also backs up the liquid in the downcomer, causing an increase in liquid holdup on the plate above. Depending on the degree of flooding, the maximum capacity of the column may be severely reduced. Flooding is detected by sharp increases in column differential pressure and significant decrease in separation efficiency.
Column Diameter
Most of the above factors that affect column operation is due to vapour flow conditions: either excessive or too low. Vapour flow velocity is dependent on column diameter. Weeping determines the minimum vapour flow required while flooding determines the maximum vapour flow allowed, hence column capacity. Thus, if the column diameter is not sized properly, the column will not perform well. Not only will operational problems occur, the desired separation duties may not be achieved.
A hydrogen bond is the attractive interaction of a hydrogen atom with an electronegative atom, such as nitrogen, oxygen or fluorine, that comes from another molecule or chemical group. The hydrogen has a polar bonding to another electronegative atom to create the bond. These bonds can occur between molecules (intermolecularly), or within different parts of a single molecule (intramolecularly).[2] The hydrogen bond (5 to 30 kJ/mole) is stronger than a van der Waals interaction, but weaker than covalent or ionic bonds. This type of bond occurs in both inorganic molecules such as water and organic molecules like DNA.
Intermolecular hydrogen bonding is responsible for the high boiling point of water (100 °C) compared to the other group 16 hydrides that have no hydrogen bonds. Intramolecular hydrogen bonding is partly responsible for the secondary, tertiary, and quaternary structures of proteins and nucleic acids.
I think your dead on point....flyingdutchman wrote:Sorry LWTC I am not neccessarily right and its is entirely possible that its exactly as you describe it, thats just how I see it.
My understanding of it is.
Mass transfer. The movement of the different compounds within the column. Whether they are being carried up the column within the vapor movement. Or being carried down within the liquid draining down the column.
Phase change. Would be the changing from one phase (vapor) to another phase (liquid). Or visey virsey. From liquid to vapor.
Separation. This would be the actual separation of the different compounds. And is carried out during the phase change and mass transfer operations. It takes both mass transfer and phase change to get separation.
Basically you have a vapor rising carrying alcohol and water with it.(mass transfer) It goes through a phase change from vapor to liquid. Then the liquid drains back down the column. (mass transfer) And again as the vapors rise through the liquid the water in the vapor does a phase change to liquid and drains via mass transfer of liquid. The alcohol in the falling liquid phase changes to vapor again and rises VIA mass transfer of vapors. So you get separation alcohol traveling up VIA vapor mass transfer and water travels down VIA liquid mass transfer.
So phase change within mass transfer = separation.
Your questions are so good frosty...Frosteecat wrote:Yes that helps but I guess I'm wondering why I'm not seeing a larger and more volatile and longer device/chamber that aids the process? Are we limited by the bubbling and change occurring due to vapor pressure (I.e. through an upcomer or perf ONLY forced by temp and pressure) or can we help make it more volatile mechanically (an "agitator" built into the system somewhere) or even by restricting vapor flow strategically as it enters an agitation segment/phase? I know it's only a piece of the puzzle but seems like it might multiply separation effect in a smaller/shorter/easier fashion...
4 plates not including the boiler or dephlegmater.flyingdutchman wrote:Maybe first thing is to look at your design again and figure exatly how many plates that should add up to.
So much of what you have been thinking is similarly contained within this concept. I didn't realize you had not seen what you have been thinking.Frosteecat wrote:Ok...now THAT looks like what my gut is telling me! I AM NOT AN IDIOT! YAAAAY!
Ahem...sorry.
