Valved Liebig
oilguy
Valved Liebig
Post by oilguy »
Newbie getiing ready to do my build, 50 L keg, 36" liebig w/45gal barrel and sump pump, My question is , will I need to have a valve on the input /output water lines or both/none ?, My pump has a 1-1/4" outlet so it will have lots of flow , just no pressure- centrifugal, Thanks,
WERAT
Re: Valved Liebig
Post by WERAT »
I would not put a valve on either side in / out. You may find that the pump doesn't push as much water through the liebig as you thought it would.
WERAT
pfshine
Re: Valved Liebig
Post by pfshine »
You might want to also put a splitter on the sump pump depending on gpm to keep from dead heading it.
googe
Re: Valved Liebig
Post by googe »
Yeah a splitter is handy, I have one on my setup very similar to yours oilguy, I put a valve on mine to, just for ease, my tanks.outside the shed, so a.valve inside is.handy.
"Homer J Simpson"
Re: Valved Liebig
A trick I learned is to just use a water spray nozzle like the one below as you can adjust waterflow without the need of valves. It screws on to your lines the same as a garden hose would and you can dial in your restriction.
oilguy
Re: Valved Liebig
Post by oilguy »
pfshine, I am not sure that I follow, "a splitter", Do you mean like a" Y" that has 1 valve on each outlet ?
What would you do with the other outlet?
Dnderhead
Re: Valved Liebig
Post by Dnderhead »
i thank he is referring to a bypass many pumps do not like to be restricted and will over heat if done so,so instead of a valve to restrict use one as a return.this "dumps" unneeded water back to tank .
googe
Re: Valved Liebig
Post by googe »
Something as simple as a 1/2" tee on the line is all that's needed.
"Homer J Simpson"
Roundyround
Re: Valved Liebig
Post by Roundyround »
IMO, a valve on the output of your liebig is prudent if you have varying seasonal cooling water temps. In winter when my barrel is 50F I don't need as much flow as when the water starts off at 80F in the summer. With a valve on the output you can insure the liebig is alway full and adjust flow for a tempeture gradient if desired.
I'm going to try a renewable grain based lifestyle. Beer and whiskey count don't they?
pfshine
Re: Valved Liebig
Post by pfshine »
The reason i suggested a splitter is you can put a little restriction on the side your not using to keep flow to your condensor and still not dead head the pump. Its like a double valved wye that fits on a 3/4 mip.
