Effect of the alcohol content
- Stavirish
What is the effect on aging with wood if the alcohol content is to low or to high?
- Jkhippie
Re: Effect of the alcohol content
Just as a guideline, 50%-55% will get more vanilla and tannic flavors and 60%-65% will get more oaky, smoky (sweet?) flavor. You could start with a mostly full container at the higher proof, then dillute a little to the lower range for the other flavors. It's really down to what you like. Experiment.
The Partridge Family were neither partridges nor a family.
If it walks like a duck, and talks like a duck, there's been a breach in the Duck Containment Facility.
- scout
Right on the money there. The higher the ABV the more movement in and out of the wood. The Jameson guys put their product in the barrel at 65% it stays like that for four years, then they will top off the barrel with spring water which dilutes the product down to 50% and then it sits for another 4 years. That's when they either bottle it up or go for the reserve which would be topped off with some from another barrel of the same batch (keeps it a single malt) and that would be sitting for 7 to 17 years. The angels share is larger the higher the ABV.Jkhippie wrote:Just as a guideline, 50%-55% will get more vanilla and tannic flavors and 60%-65% will get more oaky, smoky (sweet?) flavor. You could start with a mostly full container at the higher proof, then dillute a little to the lower range for the other flavors. It's really down to what you like. Experiment.
Just a Cooper and Whisky Maker.
"We like visitors, that's why we live in a secluded cabin way out in the wilderness"
Sweet would be the lower ABV. While the higher would be more of a spicy or Sharp.Jkhippie wrote:Just as a guideline, 50%-55% will get more vanilla and tannic flavors and 60%-65% will get more oaky, smoky (sweet?) flavor. You could start with a mostly full container at the higher proof, then dillute a little to the lower range for the other flavors. It's really down to what you like. Experiment.
