sanitation
sanitation
I would like to know how you fellas clean the coils in your still and how often.
- Cardinalbags
Re: sanitation
Rinse with clean water after each run, then allow to dry before storing away in a dry location to avoid any mold or mildew. No need to clean after each run other than above.
Do a vinegar cleaning run maybe once every 15 runs through the still.
My new still:
http://homedistiller.org/forum/viewtopi ... 50&t=44544
My old still
http://homedistiller.org/forum/viewtopi ... 6#p7083991
My controller:
http://homedistiller.org/forum/viewtopi ... 9#p7089109
My old still
My controller:
Re: sanitation
Plus one. But I mite clean mine with a vinagar run every year or two. Usually only after mods or reworking it.
Now if you had the still puke on you. That's a different story. At that point you may need to do some good cleaning.
And the still will be sterilized every time you run the still. First from heat. Then from the fores coming through it. That you are going to toss out anyway.
- upstatemoonshine
Re: sanitation
I normally discard the fore shots. So i guess i rinse my coil with boiling hot moon shine. Lol
- MitchyBourbon
Re: sanitation
I have a high pressure washer thing hooked up to a hot water faucet in my goorage. I wash out my mashing equipment the same way. I also give everything a final rinse with starsan.
I'm goin the distance...
- Truckinbutch
Re: sanitation
If ya never shut it down you never have to clean it . I just rinse mine with water and then do a steam run before the next likker run . That serves to set my flour paste , do initial leak check , and steam out any nasties that may have taken root while it was inactive .
